Anyone have LED tails AND LED front turn signals?
I had to remove my front LED turns because they were causing issues with my Eagle Eye LED tails.
Curious to see if anyone is running both without issues & how you wired things up.
EDIT: I'm wondering if these might solve the issue & allow me to run front turn LEDs w/my Eagle Eye tails
http://www.ebay.com/itm/400948987120?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I have Eagle Eye tail lights, with LED license plate lights, and no issues, haven't changed front lights.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I have both and other then the hyper-flash I've had no problems. I didn't want to cut into my factory wires for the resistors.
I have Eagle Eye rear LED lights and VLEDs Triton DRL/turn signal switchback LEDs. Each bulb has its own resistor to prevent hyperflashing.
I have had no issues from any of the bulbs.
What issues were/are you experiencing?
I posted this in the other thread but not sure if you saw it: What if you just spliced in another bulb-socket dongle to each front turn? You would still have the load from the incandescent bulbs but the BCM is expecting but you get to use your LEDs in the housings.
Yes, I have the LEDs.. I just run the resistors (although I would have much rather been sold bulbs with built in resistors) and everything works great. I guess I don't understand the problem that you are having?
I didn't get Hyperflash with the led taillights. They don't seem to be a factor.
They were hooked up right & they are not bad because they worked before the tails went in (& still did with the tails, just the gauge cluster flashed too once tails were installed)
One of my resistor packs on my Eagle Eye LED tail lights went bad and now I hyperflash on one side. Getting a replacement resistor pack is impossible it seems. So frustrating. OT, anyone know how to get one?
I purchased the "Corvettemods" LED front turn signal switchbacks and they were POS's. Both were already falling apart and the swtichback was barely visable on one side. I DO NOT recommend the CorvetteMods LED switchbacks to anyone. They make the stock HID's look like regular halogen bulbs on top of it. Not worth it. CorvetteMods gave me a tough time to return them (even though one didnt even work!). Once again, my advice is to stay away and stick with your amber stocks (or even consider straight amber LED turn signals).
PS: Never-Enough, good to see you here too
