Blow out with GY run flats.
#42
I'm confused with your $2000 vs $1300 cost comparison. Two years ago I put on a new set of Firehawk rft's, and the total cost was just under $1,200.00
#43
IMO, anytime one drives on tires that are on the wear marks, trouble usually follows. Tires will not have the traction required, are getting to the point of getting dangerous for a blowout, and if you get "caught" in a rain storm, then it's like driving on an ice skating rink.
You are right that a blowout is very rare on today's tires.
I can't believe that you would be looking for one tire to try to get another 1000 miles on the other 3 marginal tires at best.
On my original OEM GY runflats, at 4/32" thread depth, the tires were getting very getting dangerous traction wise, even in modest rain.
I replaced them with Firestone Non Runflats, changed those out at 4/32" thread depth due to road noise, although they were still OK on roads with standing rain.
No offense, however I am not sure why you use the measurement of 4/32", instead of 1/8" ?
#44
Tolero Apto Victum
I have over 200K miles on my 07 DD Vet and about 98% of that time I have had firestone firehawk wide oval rft on it. Since I work odd hours and drive about 35 miles to work, I chose the run flat tires. Due to the never ending road construction (Houston, Texas), there is no where to pull off of the highway; either you ride your rim or you will get hit, I see this all the time.
As always, each to their own & make sure to wave!
