Torque Specs for A-6 Transmission pan and Mount Bolts ??
Old 10-17-2015, 10:17 PM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
Default Torque Specs for A-6 Transmission pan and Mount Bolts ??
Changing the transmission fluid on my 2007 A-6 next week. Does anyone know the torque specs for the 10mm pan bolts and the four 18mm transmission mounting nuts to the rear aluminum cradle? Any tricks on installing the rubber pan gasket without any leaks? Thanks.
Old 10-17-2015, 10:54 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
Check the following file. That should get you all the specs that you need.
Old 10-17-2015, 11:01 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Check this video as well.
Old 10-18-2015, 12:27 AM
cmonkey713
cmonkey713's Avatar
Thank you, that's exactly what I need.
Old 10-18-2015, 09:57 AM
Mad*Max
Mad*Max's Avatar
Received 1,500 Likes on 817 Posts
Excellent video!
To Torque Specs for A-6 Transmission pan and Mount Bolts ??
Quick Reply: Torque Specs for A-6 Transmission pan and Mount Bolts ??
