Oil Pan Removal on 2007
Leaking pan gasket and the car is way out of warranty so I will need to do it myself. I have replaced many oil pan gaskets but not on a C-6. How do you raise the engine far enough to get to the front pan bolts and then clear the oil pick-up on the way down. I have floor jacks and stands but no lift. Any help would be very much appreciated.
Supporting Vendor
The thread was originally meant for doing a cam swap but all of the steps listed end up being the same as what you'd need to do to drop the oilpan.
https://www.corvetteforum.com/forums...nd-tricks.html
The following 2 users liked this post by subfloor@centurytrans:
cmonkey713 (10-28-2015),
sevinn (10-28-2015)
Yep, engine stays where its at (just braced in place) and the front sub frame is dropped down out of the way instead.
It looks like from reading the posts dropping the rack is the best for me. If worse comes to worse I could drop the cradle as a last resort. Thanks to all for the help on this.
Supporting Vendor
While you can do a cam swap by just pulling the steering rack, I'm almost positive you can't change the pan gasket without dropping the cradle.
Let me know if want some help. Never done this before but good with tools. I also have a set of shop manuals for 2008 but some of it may be the same.
oil pan sweat or oil pan leak?
I have a 2007 also and the last oil change was done by my son who is a master mechanic originally with GM and now with Mercedes for the last 15 years. I noticed a little oil film on the oil pan but never a drop on the garage floor where the car has parked for years. My son checked it and told me that it was oil sweat through the aluminum pan and there was no leakage at the gasket. Oil pans sweating oil is a fairly common happening according to him and is not that unusual with aluminum oil pans on many different makes. It doesn't happen with all of them but a fairly high percentage of them.
You may want to read trough the following thread from the forum before going though all the effort only to find the oil film still reappears.
"oil pan sweat" vs. "oil pan leak"
https://www.corvetteforum.com/forums...-pan-leak.html
Received 2,061 Likes
The construction of the oil pan gasket is not prone to leaks. Before doing any undoing, retorque all the pan bolts, clean the area thoroughly and re-check for leaks. If the leaks are at the junction of the pan, front or rear covers, and block, you'd be better off by spraying some brake cleaner on the spot and adding a dab of silicone sealer.
If the aluminum pan is somewhat porous would a powder coat on the outside of the pan seal it or go to the extreme and have it chrome plated? Just thinking out of the box here. Would there be any product or procedure that could be done to the inside to stop the "sweating"? This is an interesting topic that there seems to be no real solution at this point.
I would turn it around and say that instead of no real solution at this point, there is no real problem at this point. Many people (not neccessarily you, but many) have never looked at the bottom of the oil pan in a car until they got a Corvette and took a great interest in it. Some are under the car with a toothbrush cleaning the undercarriage...LOL. But seriously, my point is that most cars have oil on the outside of the pan, whether a sweat, a drip, a leak etc. This is far more common than a perfectly clean, dry pan. Even the leftover oil that is on the pan from when the oil was changed will spread out and attract dirt, making the pan look dirty. Unless it is dripping on the garage floor, I would suggest not worrying about it. Even if it is dripping, the first thing to do is go around and re-torque the bolts, clean it up and see what happens. This is a situation where more is not neccessarily better also.
