Vitesse Motorsports Throttle Controller - WOW!!!!
So after reading on the forums about all the throttle lag a C6 has I bit the bullet and bought a Vitesse Motorsports Throttle Controller as it has gotten so many good write ups here.
Took about 30 minutes from start to finish to install
Then like a real man, when I went on my test drive I set it in the highest setting SP9
When I mashed the throttle, I proceeded to scare the crap out of myself as the car, with my brand new very expensive Michelin Pilot Sports laid down two of the longest and darkest black marks on the street all while pulling like a freight train and swaying from side to side !
(traction control was on)
All I can say is WOW !
After wiping the smile off of my face I finally backed it down to SP6 as this seemed like the best balance of power to traction
I am sure my car is not any faster than before but it sure gets there a heck of a lot faster ...
This thing is great because unlike a throttle tune you can adjust it on the fly
I have no affiliation with this company but if you are on the fence about buying a throttle controller or even a throttle tune I am here to tell you DO IT !
It feels like a I am driving a different car and it is much more enjoyable!
Dave
Dave
I knew you would really like it! I love being able to adjust on the fly. When its raining out I just put it back to 0 but when its dry Its back on 9 for me! Well worth the $$$ Best bang for the buck IMO
How's the lag now?
What lag lol lol
Absolutely no lag at all when it is on SP 9 , throttle is instantaneous almost to much to handle .... but it will sure make you smile when you stand on it
I am sure when I get use to it I will set it on SP9 like my friend Fastone27 but for now its on SP6
Dave
Dave
What lag lol lol
Dave
Dave
Received 2,092 Likes
I wanna do it but it looks like a pain to connect it in the harness above the gas pedal.
Instead of fighting the connection at the gas pedal , I just took the two 13 MM bolts out that hold the pedal to the firewall and dropped the whole pedal assembly down where I could see it . popped it right off ....this should be in the directions ! .
I tried to take it off while the pedal was mounted and I could not figure out the secret . to easy just to drop it !
Unplugged the vehicle harness from the pedal , plugged in the Throttle Controller to the pedal , then plugged the vehicle harness into the controller , wire tie it neatly , mount the control box next to steering wheel
I am telling you guys . this thing is as much fun as you can have with your cloths on !
Done
Proud Owner (12-20-2015)
I installed mine yesterday. It was so easy a 3 year old could do it. I just popped down the black cover above the pedals and unplugged the pedal and plugged in the controller. Less than 10min I had it installed and running.
OK, I have an '07 A6. When I purchased it a little over 3 years ago it had ARH, hi-flow cats and X-pipe with a tune. Will this have any effect on my tune, or is it a simple install?
Call or Email Ahmed , he answers very quickly !
as far as the install , 30 minutes tops !!!
Dave
I will email them.
No it will have no effect on the tune at all. All this does it tell the computer that you are pushing more on the throttle pedal than you really are. That is all it does. Basicly if you push 1/4 down on the pedal than rather that signal going to the throttle body it first goes through the aftermarket controller. Then the controller pretty much lies to the throttle body and tells it that you are 1/2 way down on the pedal. It's not like some of those so called chips that plug between the IAT sensor and wire and send false timing and fuel info to the ecm.
The following 2 users liked this post by Dcasole:
02_NHRA_TA (11-16-2015),
_05C6_ (11-19-2015)
