Install oem nav stereo
Hello my name is karem
Iam new here
Today i received my item from ebay
Oem nav stereo , After installation I received an error theftlock is activtied
Can you help me ?
Iam new here
Can you help me ?
Received 2,051 Likes
St. Jude Donor '13
Unless your unit is brand new, I believe it needs to be "unlocked" by someone with a tech 2, like a dealer. Quick and easy, so shouldn't cost a lot.
It needs to be programmed to work with your car/VIN number.
You have to take it to a GM Dealer, or maybe someone with a Tech II could program it, if they really new what they were doing.
This is the procedure for getting your radio unlocked.
Connect tech 2 to car and put the car into acc mode.
At the main screen, select diagnostics
At systems selection menu screen, select body
At the vin indent screen select
Appropriate model
Appropriate air conditioning
Nav radio
At the body screen, select nav radio
At the radio screen, select special functions
At the special functions screen, select vin relearn
At the vin relearn screen, the scan tool will display, do you want to clear the radio theft information?
To begin clearing, press the soft touch key on the top right of the scan tool. The Tech 2 will display clearing radio theft in progress.
Once done, press exit on the tech 2 and cycle the ignition.
It's done and the Nav unit will now marry to your car
Appropriate model
Nav radio
lavla (11-29-2015)
The dealer charged $100 to the guy that bought my stock radio. I put in the auction text that it would need to be unlocked. He thought it was high but what do you do? Like mentioned above, all it takes it a Tech 2. May be able to find a shop or buddy that has one.
