aux and usb for oem nav radio corvette
Old 11-28-2015, 09:04 PM
Karem
3rd Gear
Karem's Avatar
Default aux and usb for oem nav radio corvette
hello guy
i can install usb and aux in oem nav radio for corvette c6 ?
my radio in the picture
Old 11-28-2015, 10:09 PM
EVRose
EVRose's Avatar
Google search "Ray Kawal". He has everything you need and great instructions.
Old 11-28-2015, 10:34 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
If you have an older C6 (before 2010 or 2011) you cannot add USB, but you can add an Aux 2 harness for I-pod etc.
Only the newer OEM radios have USB inputs.
http://www.kawal.net/corvettemods.htm
Old 11-28-2015, 10:58 PM
cclive
cclive's Avatar
I did Ray's aux in and I like it...works great. I never use XM anyway.
Old 11-29-2015, 12:47 AM
CadVette
CadVette's Avatar
I found a USB board that can be purchased from a company called Smart Home. Haven't done it yet, but I'm planning to get one. Then mount the borad inside of a plastic box you can buy a Fry's. You just have to run 12 volts to it then wire it up to a installed aux port.
Old 11-29-2015, 01:03 AM
lendellmm3
lendellmm3's Avatar
Get the isimple GSM575, cheap on Amazon only $90, and BT module just $60
Old 11-29-2015, 01:08 AM
duramaxsky
duramaxsky's Avatar
I have it as well and it works great. Just unplug the cord and XM is back.
Old 11-29-2015, 01:58 AM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
Old 12-01-2015, 01:25 PM
kawal
Emerging Vendor
kawal's Avatar
Default USB Nav radio
Your radio is one of the older factory Nav radios that doesn't support USB. You should find one of the new USB factory Nav radios from a 2011-13 C6 Vette and it will fit right in. Be sure you get GM part number 20856087 - it is the only C6 radio that has USB built in, as well as an auxiliary input port.
Take a look at this forum thread for details:
https://www.corvetteforum.com/forums...corvettes.html
And here is the direct link to the website:
http://www.kawal.net/USB%20Nav.htm
It's a pretty easy project and the radio is top quality.
Ray
One Kick (12-02-2015)
Old 12-01-2015, 08:34 PM
cclive
cclive's Avatar
No one knows better than Ray...listen to him grasshoppa
Old 12-01-2015, 09:15 PM
Dcasole
Dcasole's Avatar
Received 2,236 Likes on 1,630 Posts
I second that , Ray himself or through his many articles he has written has walked me through many of my projects and problems ...Installing the NAV radio, Power passenger seat ..... and next I am adding the aux port
He is always willing to answer a question, we are lucky to have a guy like him
Dave
Old 12-03-2015, 05:27 PM
kawal
Emerging Vendor
kawal's Avatar
Dave
Thank you guys for the kind words!
Ray
Old 12-03-2015, 05:34 PM
JJLAI724
JJLAI724's Avatar
Ray definitely knows the in's and out of the corvette. If your not mechanically inclined he's the guy to get your harness from. However if you are, you can spend $6 for a headphone plug and splice it yourself in to the XM harness. Took me 1/2 hour to splice and route the wire to the front of the cab.
Old 12-03-2015, 05:44 PM
BalloFruit
BalloFruit's Avatar
I got a iSimple ISGM655 to add Bluetooth to my 2008 nav. It also can use USB and AUX-in. Was $103 from Amazon 2 years ago. It was a simple plug and play install, the hardest part was removing the center console to remove the radio.
Old 12-04-2015, 12:52 AM
MJC611
MJC611's Avatar
Can't seem to keep aux input in '09 working. Have cleaned with alcohol and Q-tip which sometimes helps for awhile but is not permanent fix. Anyone have ideas to keep contacts clean?
To aux and usb for oem nav radio corvette
Quick Reply: aux and usb for oem nav radio corvette
