Oil Leaking
Oil Leaking
Hi
I noticed a leak of red oil under the car (driver side)
It's coming from the plate under feul tank, is that a common problem in C6? do you think it's coming from the A/T or the differential carrier?
You can see more here
I removed the steel plate under the driver side fuel tank I figured that's not an oil! it was a fuel but we couldn't fined out where it's come from, the good news it's stopped leaking even if the tank is full.
Have it taken to a shop, especially if it stopped leaking and good luck. Red oil is not fuel or engine oil and w/o a dipstick, how much ATF is still inside?
last night I was in the workshop to check this problem, the smell of that fluid is a fuel but with a viscous texture! I'll check a gain after 2-3 days also I'll check the ATF which I don't think it's the problem from the trans.
