Fuse to pull so NPP stays open?
One of the guys in my Corvette club mentioned there is a fuse that can be pulled that will keep the NPP exhaust open all of the time instead of just when I'm stomping on the go pedal. I've been searching the forum but I can't find anything about this. Is this actually possible, and if so, which fuse is it?
Thanks!
Thanks!
Race Car Tech
Thanks!
Thanks!
You might want to put a switch in place of the fuse. In sixth gear at HWY speeds it gets loud with a droning sound. Can't even hear the radio.
Plenty of suggestions on You Tube on how to do the switch and where to place it.
Received 2,092 Likes
Forum vendor sells "Wild to Mild" which is exactly what you are looking for. They work great!
Received 2,046 Likes
St. Jude Donor '13
I used the "Old School" Mild to Wild, which is a small button switch installed on the dead pedal where headlight dimmers used to be.
Cheap, easy to install, no clicker to break/lose/corrode or have a dead battery.
Mid-America has a switch that works really well. It's a really simple circuit you can probably build on your own, but Mid-America puts it into a very nice package that's easily installed and mountable.
Agreed 100%. Sounds awesome in city driving but long highway road trips will drive you crazy.
This is how I did mine
Materials Needed
OR
A simple solution (that is, if you want the open, throaty soundat the tips) would be to simply pull the 10A fuse to the dual-mode exhaust. Ofcourse, you’ll completely lose the “quiet-side” of this bi-mode system. Theremay be times that you welcome the “muffled” purr, like early morning departures,late night arrivals, or the occasional important phone conversation to name afew. Plus, how cool would it be to impress your passengers with a flip of asecret switch or press of a button.
There are aftermarket “all-included” kits for such an install,as well as a complete DIY (gather components) method. This article is notintended to endorse either option, but instead to give you a step-by-step guideto the complete process.
Step 1 – Pull back carpet and remove floorboard/panel
Pullback the carpet on the passenger side foot well. Remove the floor board/panelto access the fuse block.
Figure 1. Location of fuse block.
Step 2 – Remove the 10A exhaust fuse
Usingthe fuse puller, remove the 10A exhaust fuse.
Figure 2. The factory fuse puller is attachedto a clip on the fuse block.
Step 3 – Wire/install a mini add-a-circuit
Strip#16 gauge wire and add a male spade clip by crimping (or solder if you prefer).You may need to cut the spade clip to fit in the circuit slot. Insert the spadeclip into the add-a-circuit to extend the wiring to the switch location. Usethe appropriate length of wire necessary to place the switch where desired. Youwill also need the same length of wire spliced to the existing wire of theadd-a-circuit.
Figure 3. Add-a-circuit.
Shrink wrap or tapethese connections as desired. Install the original 10A fuse in theadd-a-circuit and install the add-a-circuit to the exhaust fuse location in thefuse block.
Figure 4.Completed integration of add-a-circuit wiring.
Figure 5. Installation to fuse block.
Pro Tip
If you have purchased a kit, Step 3 will not be necessary as therevised wiring harness will be included. Simply install the 10A fuse intogiven add-a-circuit harness and plug the harness into the fuse blocklocation. Also, if the kit includes a wireless FOB for activation, thereceiving unit will need to be grounded.
Step 4 – Run (nest and hide) the wires to thedesired location for the switch
Thereare many places to install the switch. Some have installed it in the glove box,under the dash, at an unused switch location, and even on the dead pedal on thefloor. You may need to drill a hole for the switch if desired. Using Velcro isalso an option.
Step 5 – Secure the switch and attach the wiresto the switch terminals
Itdoes not matter which wire goes to which switch post terminal in order tofunction. It may, though, if your switch has a light or LED and you prefer“light on” or “light off” to designate “open” or original functionality.
Materials Needed
- Switch kit
OR
- Mini add-a-circuit
- 2 position switch/button
- #16 gauge automotive wire
- Electrical connectors (male and female)
- Electric tape or wire shrink wrap
- Wire cutter, stripper and crimp tool
- Velcro or drill
Pro Tip
Thanks to those who went that extra mile to include the installation instructions for a switch, but pulling the fuse is only a temporary thing to give the exhaust that little bit extra for a short time as I will be getting a Corsa Sport exhaust in the next month or two.
I liked the switch idea so I went over to autozone and got the tap for about 5 bucks. Found a switch, box and some wire in the shop.
Left the tap off the wire to make it as small as possible. Pushed a length of solid copper core house wire from drivers side to fuse panel side.
Pulled it through and soldered the tap to the wire. plugged it in and tested 4-0.
Tied up wire and attached the box under the dash with Velcro.
