2008 Options Unvailable
I just purchased a clean 2008 base model 1 LT with stick, Red Tint and Chrome Wheels. I picked up the car yesterday and it's nice to drive -amazing ride for Corvette and still handles. It doesn't even rattle like Corvettes I am used to.
Anyway, the car always locks itself and I'd like to override that feature. The problem is that I can't program the DIC with either key FOB. I get "OPTIONS UNAVAILABLE".
I've read about reprogramming the fobs but the first thing that's mentioned is to disable the autolock feature which I cannot do since "OPTIONS UNAVAILABLE".
The previous owner thought the fobs might have weak batteries but the remotes all seem to work and start and run the car. I don't remember why he said that.
I would like to personalize my car as well. Perhaps I cannot because I have the base 1 LT package? I just didn't see any mention of that in the manual but there is mention of a memory package(?).
So what can I personalize on DIC and how can I do it?
Thanks for your help.
Have you tried youtube videos
Here are some forum posts on your issue. Note that after taking a look at the fob reprogramming procedure, I am guessing that disabling autolock is to make sure you don't get locked out half way through the procedure. I think rolling down the window, which the procedure calls for, would probably suffice.
Info on your issue;
https://www.corvetteforum.com/forums...available.html
https://www.corvetteforum.com/forums...t-working.html
Here is the procedure for reprogramming the fobs. You will need to do the long procedure so yours can be fob one and fob two I believe. This is from the stickies at the top of the page.
https://www.corvetteforum.com/forums...tructions.html
And a similar procedure with a slightly different layout and more information;
http://www.ls2.com/boggs/c6/C6FobProgramming.pdf
Good luck and keep us posted on your progress.
Info on your issue;
PatriotsGuy, I know you were trying to be helpful, but either you haven't owned a C6 long enough or you haven't been here on the forum long enough to be helpful.
Received 2,049 Likes
St. Jude Donor '13
And until you reprogram, you need to start wondering who out there has your other fobs...
Thanks, I've read all of the above except the PDF. The first one says to disable the autolock.
Tomorrow the sun will be out, so I'll try the PDF or ask the dealer for an estimate. But holy hell.
1LT no memory
Reread your owner's manual and see what it says about those options. Tell us the page number in the 2005 owner's manual that says the 1LT car doesn't have those programmable options.
Race Car Tech
Good Luck with the reprogramming of the Fobs for #1 and #2.
Then you will be able to change your options as mentioned.
Here is the page with that info.
FOB Learning from 2008 Owner's manual
Owners Manual
https://www.chevrolet.com/content/da...tte_owners.pdf
Owners Manual
Race Car Tech
Hopefully you have the key for the rear hatch lock. That can be a pain to get in and turn the key. Dirt seems to collect in the tumbler and make it tough to get the key in.
WD-40 work good to clean out the tumbler if it is filled with dirt.
Good Luck
Let us know if you have success.
Good Luck
What makes you think a 1LT car doesn't have memory options? Do you have a 1LT car or know someone who does?
this
