Question on C6 Drilled and Slotted Chromium Brake Rotors
Old 02-09-2016, 01:22 AM
tri08sbc
Support Corvetteforum!
tri08sbc's Avatar
Default Question on C6 Drilled and Slotted Chromium Brake Rotors
I had a question on these Chromium Colored rotors. Are they worth the money $499 per set ? Supposedly they last much longer than regular ones and they don't rust. I wonder if the color stays on the part that rubs against the pads ? Anyone have any thoughts or input ? Thanks for any help.
Old 02-09-2016, 06:02 AM
Seadawg
Seadawg's Avatar
I don't see any info (meaning part numbers, pics, etc.) to comment on. When you edited your post, did you accidentally remove it?
Old 02-09-2016, 08:27 AM
irok
irok's Avatar
Default it disappears
any coating on rotors will disappear in first couple miles of driving
Old 02-09-2016, 09:42 AM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
For around $50-80, you can take your current rotors to a local plater and get them zinc coated. If you currently have a lot of rust, it'd be better to start with new rotors. No matter what coating is added, it'll come off the swept surface quickly, since the thickness is normally less than .005" and zinc is softer than cast iron. It's better when installing plated rotors, to use the old pads until the plating is worn off the surface. That assures the new pads have no contamination and can be bedded properly.
Old 02-09-2016, 10:39 AM
tri08sbc
tri08sbc's Avatar
Here's a link to the site selling them if this helps you. I wasn't sure if it's worth it. http://www.corvettemods.com/C6-Corve...4_p_10316.html I was thinking of the black ones.
Old 02-09-2016, 10:43 AM
Seadawg
Seadawg's Avatar
gotcha Hoxxoh and irok say it well, meaning, the only part that will retain the color is around the hub, and it would have to contaminate the brake pad while wearing off the pad surface coloring.
Old 02-09-2016, 10:50 AM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
I've seen that seller's name on here before but it's always a good idea to check before you buy. jmo
Old 02-09-2016, 11:21 AM
NoXcape
NoXcape's Avatar
Dang...too bad that the color will wear off as these would look cool against any black wheel combo. Would be interested to see these on a car and how they hold up
Old 02-09-2016, 11:25 AM
tri08sbc
tri08sbc's Avatar
Sounds to me then the 500 bones are better spent elsewhere for now. The brakes aren't critical now.
To Question on C6 Drilled and Slotted Chromium Brake Rotors
Quick Reply: Question on C6 Drilled and Slotted Chromium Brake Rotors
