C6 z06 gear changing sound in 5th & reverse gear *help*
When i start my car and put the gear in reverse it makes a kreeky voice and a vibartion before but when its in place i can reverse with no problem and when im driving and shift it to 5th it makes the same voice as the reverse gear the kreeky and vibration when i push it to its gear , it would be a great help if you guys know the reason behind that
Post in Z section/tech& performance good luck
