Simple Green
Simple Green
There was a thread some time ago about engine cleaning. Several posts said that they used Simple Green to clean their engine and wheels. There is a significant use of bare aluminum on our cars and one should use caution when using Simple Green IMHO.
Aluminum - Is it safe to use Simple Green® on aluminum?
When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green® Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple Green® Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Good post; seen the caution in different forms before.
Good post...I just figure that in general, leaving any cleaner on the aluminum for a long time is a bad idea...I rinse quickly. As stated, aluminum is a fairly reactive metal, so lots of things can have an effect on it...especially anything even slightly acidic. I've always had good luck cleaning the engine, I just cover the alternator and the fuse box and keep the water away from the big connectors behind the fuse box... and never use high pressure water. I am lucky though because it is very dry where I am, so things dry very quickly.
I'm no metallurgist, but I thought one of the reasons aluminum was used extensively in the marine industry was its *resistance* to damaging corrosion from water exposure?
I thought that aluminum reacted with water/air and formed a thin skin/surface layer of oxide, preventing further corrosion? (so in effect, technically, yes, it does corrode, but its self-limiting to an almost cosmetic level)
Maybe Simple Green removes the oxide, and allows further corrosion?
We've probably got some folks here that can shed some light...
What about the barrels of the wheels that were powder coated? Is that extreme simple green safe on powder coating? If not, what would be?
I use super clean. The purple bottle.
Works great. But on wheels I just reg soap and water.
The one you have to be real careful with is "Purple Power".. I used this on my engine and it corroded my aluminum valve covers so bad , I had to remove them to buff it out and they never shined the same again........WW
PE - I use the aircraft quality Simple Green on the engine and wheels. Does a great job, better than regular SG, and safe.
Check these links:
http://industrial.simplegreen.com/in...ts_extreme.php
http://simplegreen.com/pdfs/TDS_EN-U...tPrecision.pdf
St. Jude Donor '15
"In honor of jpee"
Check these links:
Check these links:
