Changing z06/GS brake pads
About to swap in some new rotors and AutoZone ceramic pads on my '07Z. Planning to hit the rotors with a green scotch brite pad to clean up the coating. For the pads, I've been told that I don't need to use any anti squeal due to the anti rattle clips. Do I need to add any high temp silicone to any of the pins? If so, can someone share a photo of where I should apply the silicone?
If the z06 is the same as the GS you need some brake cleaner to get the coating off the new rotors some people lock tight the caliper hold down bolts.I don't.
Did you go with the padlets?? Or the one piece pads??
The calipers have individual Pistons that come from each side of the rotor so once you have those back in the bores there isn't anything else to do but reassemble.
Also one more thing you probibly already know this but brake clean will eat paint so if you have painted calipers etc you don't want to be spraying it all around or getting it on the cars paint job calipers etc.
Supporting Vendor
St. Jude Donor '11,'13
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Thanks for the replies guys.
I was going to buy sil glyde per the recommendation of others, but the guy at the parts store recommended a high temp silicone instead, saying that sil glyde would not withstand brake high temps. He also recommended not to use it on the back of the pads, only to lubricate any floating pins.
So if I'm understanding correctly, there are no floating pins that need lubricating, and it is ok to use sil glyde on the back of the pads, where they meet the anti-rattle clips?
**correction**
In the situations where I didn't remove the caliper I did remove the pins.
