Brake pad clips possibly rubbing rotor
Put new GM ceramics on 2005 C6...installed the new clips (which fit in the bracket which holds the pads and the pad nubs fit into the clips)....sounds like one of the clips may be rubbing against the rotor (right rear wheel)....I dont think its on the machined face of the rotor but possibly the outside edge of the rotor...looks like super tight tolerance with the clips in the bracket...any ideas? Thanks
I would just remove the clip and cut it down or you may be able to take a dermal and just grind it down so it does not rub. Although if it's properly installed it should not rub. Remove it and reinstall it to check its correctly installed.
Thanks, I have had it apart a few times trying to adjust the clip...maybe I tried to adjust too much and need to replace...or go to the pros...hopefully not
Another thing I was reading...maybe a rust ring on the rotor making the sound on the new pads??? I know there was some rust on the rotor...inside ring and outside ring. I painted the inside ring but did not address the outside ring...something else to check
I also had to replace those clips on one rear wheel...Found them at Autozone at a reasonable price.
One wheel was rubbing and driving me crazy.
I think these are the clips:
http://www.autozone.com/brakes-and-t...?checkfit=true
