P0300 code without check engine light!
Hi Guys,
I did heads and cam swap a month ago and the car run fine. However, I checked for codes and I got P0300( random misfire). I changed plugs and wires but its there yet. I noticed that at high RPM I get a whistle sound, I think from back of the intake. Is the code because a tune that it supposed to tell the engine there is a cam or something like that? Did anyone have the same issue? BTW, the heads are trick flow and the cam is not that big!
Thank you
Thank you
GS13 (03-07-2016)
yea bro you have to mess with the tune because of the cam the motor thinks its detecting misfires i think what is happening is the tune was just set to not set check engine light for p0300 but its detecting the error
GS13 (03-08-2016)
