Water pump
Old 03-31-2016, 09:46 AM
qtip
3rd Gear
qtip's Avatar
Default Water pump
Anyone know of a reliable corvette shop in Tucson Arizona
Old 04-01-2016, 07:57 AM
C6ToGo
C6ToGo's Avatar
Received 1,108 Likes on 690 Posts
The water pump is a pretty straightforward swap on vettes.
If you can't find a corvette specialist, I imagine any decent shop could handle the task.
Old 04-01-2016, 05:28 PM
qtip
3rd Gear
qtip's Avatar
Old 04-01-2016, 09:05 PM
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,043 Likes on 1,357 Posts
St. Jude Donor '13
It should be easy, but be sure they refill with Dexcool and not the green stuff.
Distilled water instead of (permitted) tap water for the 50-50 mix is a nice touch.
Old 04-01-2016, 10:13 PM
v26278
v26278's Avatar
If you have any mechanical aptitude at all it's any easy DIY, aside from the usual cuss words and a skinned knuckle or two. It took me 3 hours and I was in no hurry.
Old 04-01-2016, 10:46 PM
C6topless
C6topless's Avatar
It is really is a very simple process to swap out the water pump...
remove the belt...
drain antifreeze via the plug on bottom passenger side of radiator.
remove bolts from water pump
pull away
If your new water pump does not come with a new thermostat, now is the time to replace it.
reverse process.
when filling with new coolant, make sure you put in the right mixture. also a vacuum tool to refill will help ensure no air pockets.
To Water pump
Quick Reply: Water pump
