2007 passenger window problem
My problem is that the passenger window switch will not lower the window. I can lower it with the master switch. The passenger switch will then raise it without a problem. It (passenger switch) just doesn't raise it. Does this sound like a bad switch? All help is appreciated.
Took it apart and cleaned contacts. Installed and still the same. Ordered new switch which was only $15.00. Hopefully that will do the trick. Thanks for responding.
