C6 driver door window regulator module full of water
5th Gear
Recently had my 2005 C6 coupe detailed and then window regulator module failed and nothing in driver side door would work. Ordered a new module online because it was much cheaper and then took it to the dealer to have installed. When they took the old module out they said old one was full of water. Not sure if this happened during the detail or a recent rain. However, I did have the exact same part replaced about two years ago. They did not mention whether there was water in it at that time. What should I be looking for to make sure this doesn't happen again? Not sure if my door/window is leaking or not draining or what? I asked the dealer when I picked it up and they did not have any answers for me but the water must of gotten in there somehow so I want to fix the problem not just keep replacing the module/window assembly. Any help is much appreciated!
In all seriousness that is a weird phenomena. I've never heard of that.
Inspect your window dew wipes. The are the rubber/felt seals at the bottom of your window that attaches to the top part of the door. They should show no signs of cracks or dry rot and should be pressing against the window without any gaps. I suspect it's the outer dew wipe that's letting water in when it rains or the car is washed. If you have to replace the outside one I recommend doing the inside as well.
