C6 anti sway bar
Why is that leaf spring still on there? Seems to me if the leaf spring is removed it will allow the suspension to raise higher to maybe allow enough clearance for the end link and the sway bar. Beyond that I would communicate with QA1 to see if the coil overs require different sway bars and end links.
Anti sway bar / QA-1
As stated above, the leaf needs to be removed, but I can't see that it has anything to do with the sway bay hitting the coil spring. Is it hitting the springs on both sides or only one? If it's only one, then it may just be that the bar wasn't centered when it was installed. It will tend to center itself, but of course no one wants to drive it with the scraping until it does center itself.
the guy above me is correct. The reason it's not sitting funny now is because you've still got the leaf spring in the car holding it up. You'll just have to crank the collars up high enough to clear the sway bar. Which you were going to have to do anyways, no reason to cut anything up
Thanks, I did contact QA-1 and they said the same thing, that the Coil-overs replace the mono leaf and it should be removed. I didn't know, wasn't prescribed anywhere. The learning never stops. If that doesn't cure the problem I will probably modify the mounting end of the swat bar by cutting it back a bit, grinding a new flat, and re-drill the mounting holes. Thanks again for all the input.
