Seat belt tension issue
Old 05-25-2016, 12:42 AM
Hebebad
Hebebad's Avatar
Default Seat belt tension issue
The passenger side seat belt locks in place once you buckle it while the driver side stays loose. Is this normal? Thanks.
Old 05-25-2016, 01:50 AM
fred D
Support Corvetteforum!
fred D's Avatar
You need to unbuckle the passenger belt and let it retract all the way. then start all over hooking it up.
Old 05-25-2016, 07:34 AM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
When you pull the seat belt all the way out it ratchets.
This allows you to cinch it up tight if you need it (racing/etc.).
To release it you have to fully retract it and start over.
Old 05-25-2016, 11:49 AM
cclive
cclive's Avatar
Some people have a habit of pulling the seatbelt way out before buckling it...this causes the ratchet effect...it's a feature not a defect. Don't pull the belt out any further than is necessary to buckle it.
To Seat belt tension issue
Quick Reply: Seat belt tension issue
