Clunking Noise Coming from Rear of '08 C6
Two years ago I had to have my left rear axle replaced because of a cut boot which was seeping grease. Took to a local dealer and they replaced it with a new GM axle. Within a year I started to hear weird noises coming from the back but didn't pay much attention to it thinking it might be the exhaust or end links. Recently it has gotten to the point that I need to figure out exactly what is causing the noise. The dealer mentioned the end links on the sway bars so we replaced but the noise was still there. We wondered if it could be the rear axle that they replaced earlier. The dealer assured us it wasn't the axle.
Driving at speed on the highway or slow speeds up a slight grade there would be no noise. But driving down the same hill with rough payment and not touching the gas pedal (coasting) the clunking sounds would return. It sounds like when there is no torque on the axle the clunking sounds return. On my own, I lifted the car, released the hand brake and put it in neutral and rotated the wheel back and forth to listen for the sound and heard it coming directly from the inboard cv joint and rubber boot.
I decided to just go ahead and replace both axles and wheel bearings at the same time, doing the work myself.
Now that I have the axle out and on the work bench, I notice that the inboard cv joint had a very loose and shaky feeling that clunks when you rotate it back and forth. In comparison the new axle is solid and has no clunking sound. I haven't reinstalled them yet but I'm pretty sure that this should solve the clunking noise at the back.
My question is: Does anybody know if the rubber boots on both ends of the axles are all made in Canada? The reason I ask this is that the clunking noise comes from the end of the axle that has the boot made in Japan while at the other end of the axle the boot is made in Canada. All the boots on the new axles (GM Parts) are made in Canada.
I'm wondering if this is a rebuilt axle with a replacement boot or is it possible that GM builds their axles with boots from different countries?
Anyone have any knowledge of these boots and why an axle could go out so quickly (less than 20,000 miles)?
The bad axle with the Japanese Rubber boot is on top and the brand new GM axle is on the bottom.
You'll notice that the housing is much larger and sloppy compared to the new GM piece.
Is this normal or do you think there are different style axles for the C6?
I've replaced both rear axles, both rear wheel bearings, all new end links on the sway bar. I even disconnected the rear shocks and drove the car and the clanking is still there! I've given up and I'm just learning to live with the noise.
CammedC6520 (03-21-2017)
Received 2,882 Likes
When I replaced my axles they were OEM and were like the smaller ones.
One suggestion is to remove the front end links and test for noise. Seems the noise from the front end links travels and sounds like it is in the rear. LG Motorsports removed my rear ones first with no results. Then removed the front ones and the noise in the back stooped. Put on new front end links.
Easy to check and it is free.
I'd still keep investigating. Inspect the control arm bushings and if you have a Z51 package make sure the extra stabilizer link is not worn out and is lubricated. There is a grease fitting located near the wheel. Grab on to any suspension part that moves and shake them firmly to try and find any play. Good luck.
The following 2 users liked this post by CadVette:
CammedC6520 (03-21-2017),
Euthymicone (09-19-2018)
We also took our car to Abel and Jim went out for a test ride and we couldn't figure out the problem even after complaining a few times. If you find out the problem, just let me know. Your right, sure it can't be good just not sure what else to do other than replace the Magnetic Shocks which may or may not be the problem.
Looks AWESOME
I wanted to see how smooth your side skirt to rear fenders turned out and it looks awesome! I want to do something similair and blend into the C06 rears instead of just putting zr1 skirts on like most do.
photos
(Unrelated) I took a few pictures of 83 team yojack car the other day on my road trip. I was looking up on fb no luck. Email me and I will send them your way. Danielle.keyes1984@gmail.com
