Brake replacement ?
Brake replacement ?
Capitol Chev in Keizer told me I have 31% left on my front pads; 80% on the rear pads. If I were to replace the front pads, do I replace the rears.......because I do not know if the rears are "normal"---ceramic or ???? Can I mix?
Jayhawk62 (06-08-2016)
At F31%/R at 80%, your brake fluid in the system was due for a power flush and air bleed out of the lines a long time again. Yes, the fronts will wear out at a slightly faster rate, but should not be that much of a faster rate instead.
As for just replacing the front pads now, replace them with the same pads the the set has to maintain your braking Bias (one the system is flushed with new fluid and the air bleed out of the lines).
If you want to go to a different type pads (say Duralast ceramic pads since they are very inexpensive on a Base model) then change all the pads on the car to them.
As for rotors, you may still have enough metal on them to be able to be turned (or at least cleaned up with both surfaces squared to each other.
Now the bad news, if you have the dealer do the brake job, then are going to replace the rotors with new, and install A/C Delco pads. The price for such is going to be just short of $1K, while if you just need to have the rotors turned and pick up say the Duralast ceramic pads, your into the project for about $125 isntead (including brake fluid to power flush the system and breed the air out of the lines when your do as well).
If such is beyond your talent level, then check around with other local Vet owners, and someone may be able to give you a hand since it only about a hour job.
Supporting Vendor
St. Jude Donor '11,'13
Low dust stops like OEM if not better and last longer. 100% non-corrosive dust will not harm your paint or wheels.
If interested let me know I will be happy to help you.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F:1521 $140.00
Look to amazon or rock auto for the rotors they should be in th $45-$50 range.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
