Heated seats
Heated seats
Has anyone ever changed their un heated seats to a heated seats,besides buying the heated seats can this be done and just wondering what all i have to have and will need ? Talking about a c-6
http://l.jegs.com/jegs40/c2.php?=wWah1WZxIjNwYTMwITPudWahBXbhN2Xt RXdm82Zvx2cnVma9Qnbl
Don't worry about the SA comments. Some think that everyone must do a complete search before you are allowed to ask a question.
Of course you will need to change out your seats for a set with the heating elements, the console cover to allow you to put the switches in (as long as you want it to look factory), and I am not sure if the wiring is there or not. Sometimes a wiring harness has the connections for the different options. If not then you have a lot of work ahead of you with all new wiring.
mtndue88 (06-26-2016)
mtndue88 (11-13-2019)
https://www.corvetteforum.com/forums...-in-a-1lt.html
Here is a post for an aftermarket kit that looks pretty cool.
https://www.corvetteforum.com/forums...oryourcar.html
Good luck!
Had heated seats installed in a Lincoln I had.200 a seat.Had it done at a place that installs stereos.
I put them in my Expedition and installed the switches in the factory position as most kits use a Ford type switch so it looks factory .
I have been playing with the idea of installing them in my coupe but not sure if I will like the rocker type switchs installed by the ashtray .
I have been trying to figure out a way to use them but it was just way to complicated .....
I might just bury them in the carpet ...
Thanks!
Dave
