back up light fuse?
Old 07-02-2016, 12:11 AM
NARIMAN
NARIMAN's Avatar
Default back up light fuse?
how can i find which one is the back up light fuse?
thanks
Old 07-02-2016, 07:03 AM
Knob Jockey
Support Corvetteforum!
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
Do you have an Owners Manual?
There are 2 fuses in the passenger foot-well fuse box.
"BCK/UP LAMP" and "REVERSE LAMPS"
And there's 1 fuse in the engine compartment fuse box.
"STOPLAMPS/BACK-UP LAMPS" But if your brake lights are working this probably is not the problem.
If the fuses are all good, the next place to check is the large connector inside the rear bumper cover. It's directly below the outer light on the passenger side. Take it apart and clean it and use some dielectric grease on the contacts when you re-connect it.
Landru (07-04-2016)
Old 07-04-2016, 01:03 AM
NARIMAN
NARIMAN's Avatar
Thanks!
To back up light fuse?
Quick Reply: back up light fuse?
