Windshield Wipers won't work
Hello all, I've searched the forum and I couldn't find anything on how to fix this. As the title reads, I can't seem to get my windshield wipers to work. I would tell you why I needed them, but that of course is a cardinal sin. When I try to use them, it doesn't work. I've tried changing the speeds, using the windshield fluid, and I've gotten zero response. I may or may not have made a rookie mistake and left the car on without the engine running. I know crazy me. The car was on for roughly 4 hours, and I drove it to keep the battery from draining. Next day, I got zero response from the wipers. I'm assuming a blown fuse is the culprit, but I don't know. Does anyone have any ideas on how to fix this so I know what to look for tomorrow?
Thanks,
Nikko
Thanks,
Nikko
Received 1,110 Likes
A start:
Wipers Inoperative - All Modes
Diagnostic Aids
If the 30 A WIPER fuse located in the underhood fuse block is open, a short to ground in any one of the following circuits may be the cause:
• Windshield wiper motor high speed circuit
• Windshield wiper motor low speed circuit
• Windshield wiper motor park switch voltage supply circuit
• Windshield wiper motor park switch signal circuit
• Accessory voltage -- WIPER RUN/ACC relay switched voltage circuit
If the 10 A WPR/WASHER fuse located in the instrument panel (I/P) fuse block is open , a short to ground in any one of the following circuits may be the cause:
• Accessory voltage circuit to the wiper switch
• Windshield washer switch signal circuit
• Windshield wiper switch low signal circuit
• Windshield wiper switch high signal circuit
• Windshield washer relay control circuit
• Headlamp washer relay control circuit
Diagnostic Aids
A start:
Diagnostic Aids
Diagnostic Aids
