film inside headlight lens
Is there away to takeout one of the headlamps and be able to wipe the inside of the headlight lens , Ive owned the car for 6 months and it has driven me nutz because there is what looks like a film or dust inside the headlight lens on both sides, It is the only project I cant figure out how finish .any help would be greatly appreciated, thanks
Heck there are posts on this board where people bought brand new lights from GM and they had dirt or were cloudy
Unfortunately, the lenses are glued on to the housing so the only way to get them off is to put it in the oven and heat it off which usually results in damage to the lenses , this is how people get them off when they are replacing their cloudy or damaged lenses
Which brings up the next point , if you do damage the lenses , they are not available any more ...... as GM stopped making them . RLSEBRING , a forum member who was selling them is trying to source them but so far he has not been able to locate any
Another member was successful in cutting his off and then regluing them as he wanted to paint them , but that might be to much of a chance to take now that if you were to mess it up you could not replace it
My lights look great but the coating was coming off , been looking for new lenses for a long time and finally I found what had to be the last set of Torch Red lights , they came off a car where they guy switched his out to black and the car only had 10,000 miles on it , its a gamble I know but ....
So in short , the answer right now is you might have to live with it
Dave
Quite some time ago there was a detailed post here. Someone took out the headlights out, removed all bulbs and the circuitry and washed them through the socket halls. ( multi step). That part was detailed because you do not want to leave water spots in side the lenses. Do a search, hopefully you can find it.
I bet if someone here was successful it would make a lot of people happy
Dave
Originally Posted by Dcasole
Maybe if you use ionized water??
Dave
Dave
