Tunnel Insulation?
St. Jude Donor '11, '14
Tunnel Insulation?
I am adding headers and want to put insulation up in the tunnel.
Looking to find out how many square feet I will need and doI just spray adhesive and stick it on. I have seen silver tape used?
Thanks in advance for any info..
Robin
Robin
I used the DEI Floor and Tunnel shield 4' x 21". It was not quite enough to do the entire tunnel, but I had the plate off and was not waiting on another order. I would estimate you would need about half as much more to do the entire tunnel, perhaps a little more, plus waste, so I would error on the side of two of these rolls.
As I mentioned, I did this at the same time I did a tunnel plate, so I don't know which contributed to the overall heat reduction more, but it is now more comfortable. My wife and I went for a three-hour drive Sunday in 80 degree weather. Tunnel was warm at the end of the ride, not burning the side of my leg.
Good luck!!
Good luck!!
The following 2 users liked this post by NMJoe:
theandrewo (09-30-2018),
zrracer (08-22-2016)
