Please help. 2005 won't start. Electrical issue
I have a 2005 Corvette. Battery kept going dead so I replaced it.
Now, with a fully charged battery, when I hit the start button the entire electrical system seems to just go dead. No attempted crank, nothing. It's as if the start button is a lights off switch for everything in the car. After about 5 to 10 seconds, the dash lights come back on. Repeat and it does the same thing over and over.
Any ideas?
Any ideas?
Received 3,611 Likes
2016 C6 of Year Finalist
Any ideas?
Any ideas?
I think I had to lock and unlock the doors before it would start.
Any ideas?
Any ideas?
Look at the top of the starter motor where the positive cable attaches to the soleniod and make sure the connection there is not loose or broken. The bakelite plastic can crack creating a poor or no connection at that point.
This one is real bad...
If you find nothing with my first posted check, a good idea would be to
check the connections behind the passenger carpet foot rest where the fuse box and the BCM unit is (blue connectors).
These harness connectors have been know to create all kinds of issues with the operations of these cars. Pull them apart by lifting the little swing arm and investigate all the pins for cleanliness and looseness .
May have to lift the car to get a better look it.
Looking between the passenger side header tubes, you'll see the starter motor and starter solenoid.
In the photo, you can see where mine cracked and broke, and one of the posts came out of the starter solenoid. Note the large hole in the solenoid plastic.
Appreciate all the posts. Don't see any obvious loose connections on the starter. Checked the electrical connectors too. Guess I'll have to get it towed in.
Last question - how difficult is it to replace the starter on a C6? I have a buddy who works on cars a lot and says he can do it. Easy enough for a backyard mechanic?
thanks again
thanks again
One m0re thing to add -- Before this occurred, something seemed to be draining the battery. The battery I replaced was less than a year old, and the new battery went dead shorty after I installed it. Does that tell you anything?
But something could be draining your system, as a new battery should hold it's charge unless it wasn't fully charged to begin with or it's defective.
Received 1,136 Likes
From The School of Hard Knocks, when a car won't turn over and you have no reason to suspect a dead battery:
Step #1 - Check both ends of both battery cables for cleanliness and tightness, and visually inspect the cables themselves. The ground connection is just as important as the hot.
How much was it to fix it ?
I had a problem that the wiring in my steering column would short when it sat in the sun all day. You may want to check the steering column wiring. Mine was an 05 also.
Took a few hours to move the header, remove the starter assembly, install a new starter solenoid, reinstall the assembly, and re-bolt the header.
Cost of the solenoid was about $20 vs the $100+ for the entire assembly.
Found here:
Quoted from another post:
"I took my starter to a local starter house and they installed current Delco part # 66-161. Original Delco part # 10503939. If you search on either of these part # you should be successful at buying a solenoid. This information is valid for my for a LS7 and suspect other LS starter motors but I didn't not verified. This solenoid has (3) bolts on the starter nose to attach it to the starter. It has the single round plastic snap on connection for the start wire connection."
There are also videos out there on how to use jumper cables on your car battery to test the starter solenoid and starter motor, but the assembly has to be out of the car to do so.
Found here:
This happened to my ‘05 manual roadster, no crank and no start. I also had a check engine light with a P0335 code. I put in a new battery and new crankshaft position sensor with no help. After days of diagnostic checking I swapped the crank relay with the rear defog relay and it started right up. The rear defog light on the switch then wouldn’t light so I knew it was a bad relay. Easy fix but what a pita. Relays are # 40 and 43 in the under hood fuse box in front of the battery. Check engine light went out and all working fine now.
rc51racer (11-14-2019)
