pcv question
Old 10-03-2016, 02:16 PM
psxer989
psxer989's Avatar
Default pcv question
On my ls2, I didn't pass the visual on the smog test because I'm missing the pcv connection on the driver's side valve cover on the back. It just has a plug. I pulled my supercharger earlier this year and didn't realize that it mush have been removed for the initial install.
Anyone have pic or part number so I can put it back to stock?
Old 10-03-2016, 02:51 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
Here is a pic with part numbers. I'm not sure if what you are after is in this pic, but I'm hoping it is.
I've added the PDF link to LS2 parts for the whole car.
http://www.autoricambi-euroamerica.c...ofessional.pdf
Here is a pic of the back of the engine.
Old 10-03-2016, 04:04 PM
psxer989
psxer989's Avatar
On the left side of the engine picture, the valve cover has a black plug. That's what mine has. Smog inspector says there is supposed to be a pcv hose connected. Is he just flat out wrong?
Old 10-03-2016, 05:12 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
I have an LS2, so I'll try to get a pic for you as to what is connected there, if anything.
The pic seems to show a PCV type end connector next to that black plug.
I got a few pics, and where it's capped, that's how it's supposed to be for an LS2.
The PVC line goes behind the motor, next to the fuel inlet line by the firewall, then goes under the car towards the back. I didn't follow it under there but pretty sure it's the evaporator line going to the fuel tank.
Old 10-03-2016, 05:22 PM
psxer989
psxer989's Avatar
The tech said the plug is not stock. I don't believe him. I guess I should have left my valve covers on.
Old 10-03-2016, 06:19 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
According to what I'm reading on this, that port that is capped on the rear of the valve cover on an LS2 is supposed to be that way.
Here is some sort of explanation on PVC routing for an LS2.
The blank is a 3/8" rubber cap GM#12579145 (the black cap in the above picture)
All it does is cap off an outlet that never gets used in LS2 application.
The valve covers are multi-purpose and get used on other engines where this outlet does get used.
http://www.ls2.com/forums/showthread...S2-PCV-routing
Old 10-03-2016, 06:38 PM
psxer989
psxer989's Avatar
Thanks. I think I'm going to use a different smog station rather than argue with the tech. If it is illustrated in the service manual then I might go back to him and show him.
Old 10-03-2016, 07:15 PM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
My car is totally stock, so as you can see, that cap is on my valve cover from the factory, as it is in the Crate motor picture that I posted prior.
Good Luck
Old 10-03-2016, 07:40 PM
BlackLS
BlackLS's Avatar
2023 C5 of the Year Finalist - Modified
St. Jude Donor '17-'18-'19
My LS2 has a cap on the drivers side valve cover.
Here is a picture of the valve cover. It was removed because I recently installed Holley Valve Covers.
Old 10-03-2016, 07:43 PM
psxer989
psxer989's Avatar
Thanks everyone! Basically the smog tech doesn't know what he's talking about.
Old 10-04-2016, 01:34 PM
irok
irok's Avatar
he dosent have a clue about what he is talking about.that cap is what the car comes with from the factory on the LS2 Corvette.On the Trailblazer SS LS2 there is a hose going to that fitting
Old 10-04-2016, 09:24 PM
z06scentair
z06scentair's Avatar
The PCV is internal, located on the underside of the valley cover. There is a port running from the top front right side of the valley cover to the intake manifold port on the ls2.
Old 10-05-2016, 09:38 AM
MIGHTYM0USE
MIGHTYM0USE's Avatar
trucks and i have seen on some pontiac g8's they use the driver cover and either no port on the valley or it is capped.
all the other cars that ive seen (except dry sump) have the driver cover capped and use the valley to vacuum the crankcase.
all of them use the passenger front valve cover for fresh air source
To pcv question
Quick Reply: pcv question
