Brake calipers torque specs?
Changing rotors,what torque value is needed for the bolts holding caliper to the hub assembly?
[QUOTE=RicK T;1593357746]23 ft/lbs and use blue Loctite.
No, 23 is for the caliper pins. Torque is 129 for the bolts holding caliper to hub
Just a suggestion from personal experience.
Do not use 3/4" impact (or larger) to snug up the caliper mounting bolts. Even if your impact is rated for <125 ft /lbs of torque it can still generate enough force to break the caliper bolt retaining sleeves loose in the caliper body.
Hand-tightening is your friend (in this case).
Not sure how you determined they weren't tightened to that spec at the factory as the force required to remove a bolt is not equal to the force required to install it but I understand if you had some concerns about applying 129 ft/lbs of torque to a bolt that is going in to a threaded steel retainer that is just pressed in to an aluminum caliper.
Lots of factors go to difficulty of removing bolts previously torqued to a specific value:
1. Fastener type
2. Use (or lack) of anaerobic locking compound (LocTite)
3. Compatibility of bolt / retainer and the effect of galvanic corrosion
4. Heat/cooling expansion cycles
5. Incorrect torque applied in the first place
In my case I think I was the victim of the previous owner of the car having someone R&I a caliper as part of some service and the guy hit it with a 250 ft/lb 3/4" air ratchet.
1. Fastener type
