service active handling came back
Old 11-16-2016, 12:16 AM
soheil
soheil's Avatar
Default service active handling came back
Smh
Old 11-16-2016, 09:25 AM
RJS91RGTP
RJS91RGTP's Avatar
Default Service Active Handling
Originally Posted by soheil
So a bit over month ago it came up when i drove 15 mins and then went away. Today it happed again. I cant figure why because car operates perfectly. Its 08 model without telescoop wheel. Only think i can assume is maybe uneven tire psi but like 1-2psi shouldnt bring that message idk
​​​​​​​edit: rear are 220 kpa. Front left is 228 but front right is 204. How does this happen that front righy tire didnt warm up like rest?
The DIC message has nothing to do with tire pressure!! Most likely cause is the wheel position sensor starting to go bad. Not an expensive fix but one that needs to be done by a dealer. It will get worse over time so get it checked and have the code pulled to verify.
Good luck!
RJ
Chicago, Illinois
Quick Reply: service active handling came back
