Radio blues
Radio blues
Bought a 2005 beautiful blue C-6 and boy do I love it!
Now please be easy on me cause I'm brand new to the C-6. I'm first having the harmonic balancer changed just because the problem I've heard of them.
NOW THE PROBLEM. The radio does not work. When it's on it just sounds like the antenna is disconnected or that's what it sounds like. Popped a CD in the make sure if it wasn't a speaker problem and played soooo good. Any one have this problem or am I missing something or setting or where do I start. I have two C4's now ( both '92's a drop-top with the rare hard top accessory and a FX3 coupe) and I know about the Bose problem as most of them fail.
I Just bought this car so again I'm new to the C6. It a '05 6.0, 6-speed with 60K on the clock.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Aside from those questions, if you're experiencing problems with only AM or FM, then it's possible an antenna lead became disconnected. If both are affected, then it's quite possible that something in the receiver section of the radio has failed, such as an RF (radio frequency) preamplifier, or something common to both the AM and FM. The rest of the radio system (amplifier, speakers) must be OK as you mentioned a CD sounded good.
Steve
Race Car Tech
Thanks in advance
Thanks in advance
I can also send you a color coded wiring diagram as well.
It may be as simple as the antenna is disconnected from the back of the radio. You will have to remove the radio surround console to get the radio removed to access the back where the antenna plugs in.
I have instructions to remove the console if you need them.
Race Car Tech
Here is a Jpeg of the BOSE premium system and the Base radio/CD disc changer systems.
Copy images and zoom for better clarity
Do you live near any AM or FM stations? Also, you did not mention whether or not the problem was with AM only or FM.
Steve
Steve
Yes does it on both FM and AM and sounds just like the antenna has been disconnected.
I have found on my 2006 that the antenna is not stellar. I have an aftermarket stereo in with a very good FM receiver that I had installed in my C4 previously and I have found that I get FM fade at about 55mi from source at times.
Race Car Tech
