Help with Car Battery Removal
Hi, I have a 2012 Grand Sport convertible and because it IS a convertible it does NOT have the dry sump oil system and because of that its battery is NOT in the trunk like it apparently is in GS coupes. Instead my battery is up front on the passenger side near the fire wall.
I'm bummed to see that battery removal is not even mentioned in my manual other than to tell me to see the Service Manual which I don't own.
My battery has died quite suddenly. Assuming i can jump start the car again as I did earlier today (with great difficulty)(and I just checked and it's now not able to start the car again on its own) I intend to drive it to the dealer and have them replace the battery for me. However, if I can't start it or if I just decide to go a route of doing this myself, I might go buy a battery and bring it home.
So, can someone share how hard/easy it is to remove and replace the battery in my '12 GS convertible??? I've attached a couple pictures of what appears to be a clamp like device at the base of the battery on the front side. My guess is that perhaps if one loosens the nut on top of that clamp like device (??), that the clamp can either come off or move out of the way at least so with the two battery cables removed, one could perhaps just lift the battery up off the tray and out of the car???
yes??? no??? And if you do get it loose is it hell to maneuver it out through the gap through which it needs to move or is it easy??? And what about putting one back in??? Easy??? Hard???
Any help would be much appreciated... Or maybe even a service manual page if that's easy??? I will also go look to see if there are any good YouTube videos on this task.
thanks much... bob
thanks much... bob
And here are the pictures I said I would attach but didn't do so above...
The round, silver thing is a washer under a nut. I'm guessing but it appears that perhaps if you undo that nut, the rubber or plastic looking clamp can perhaps be moved away from the battery to free it??? And I sure hope this is simply a stop and not another clamp on the backside as I would have no clue how one would ever access that side.
Thoughts on my post above about how to remove this battery??? And add a new one in its place???
thanks... bob
thanks... bob
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
And I sure hope this is simply a stop and not another clamp on the backside as I would have no clue how one would ever access that side. thanks... bob
Pull the battery straight up and out of the car.
You have never changed out a battery in a car before?
Replacing the battery is simple ... Remove both battery cables and remove that "washer under a nut" you mentioned ... that's the only removable battery hold-down you have.
Make sure you remove the negative cable first on your old battery. When installing the new battery, install the negative cable last. This will make sure you do not spark the cables.
Yes, but never have I changed a battery in a Corvette... And I've done enough work in cars to know the devil is always in the details, like can the battery really come up out of the hole without you having to remove other cables or whatever... Thus the reason I asked... thanks... bob
You will need to re-index the side windows after replacing the battery.
At least you do on a coupe ... I would think that it would need to be done on a vert too.
Instructions for indexing the windows are found in your owners manual.
Don't forget to re index your power windows. If you know someone with a tender that you can use for the day , that may give it enough juice to start the car. If not the removal is not too big a job.
To the OP- Something to keep in mind before you try to drive your car with a dead battery, the car requires the battery to have a certain amount of voltage or it won't run properly. Modern cars do not run off of the alternator as 60's or 70's cars did. They require both a working alternator and a charged battery or it will not be able to run all of the required systems. It's very possible that it won't even fire on all cylinders.
As said in post #5, it is very important to remove the NEGATIVE cable first, then the positive cable. When you install the new battery, connect the POSITIVE cable first, then the negative cable. This will avoid a possible spark which could result in the battery blowing up.
This is well said. So with that in mind changing the batt should go something like this......Dis-connect old battery......loosen and remove hold downs. Remove old battery. Place in new battery and reverse procedures. And watch your fingers !!!!!....LOL
Received 2,093 Likes
And if you are lucky like I was on my 2010 base I did NOT have to reindex the windows. You will have no problems. It almost takes longer to explain the process than to do it!
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I see it's been said at least twice but just to reiterate, there is one thing that is well-known and a problem. Loosen those nuts on the battery cables, but make sure NOT to let them drop off. First, they can be difficult to find in the engine bay unless you get lucky. And last, they are not easy to find replacements for, and they are odd in their cut. Your cable will not tighten on the post with a regular nut as a substitute.
As a last precaution, I figured it couldn't hurt anything if I placed a worthless blanket over the nearby fender just in case I smacked it with the battery as I was pulling it out, or swinging it over the fender to the floor. I did, I did, and I did. And thus, no damage. Just kind of laffing at myself the whole time.
Received 3,626 Likes
2016 C6 of Year Finalist
