Vitesse goes wild
Vitesse goes wild
I have a Vitesse controller installed on my 2006 Base C6. This morning I pulled up to bank and noticed it said A20 instead of the normal sp2 that I keep it at. I pressed the button to hopefully bring it back to normal and the engine began accelerating all the way up to 5K before I turned it off. My foot was not on accelerator. I restarted car and it threw a code about throttle problem and restricted power. I reset engine code and now it seems fine. I should have saved CEL code but did not. I was in a hurry. Seems a little scary. What should I do?
Check with Ahmed at Vitesse, he is very knowledgeable.. The numbers will scroll as you drive, but the RPM increase sounds odd. I have never had a problem with mine. I keep mine on 8.
The A20 indicates 20% throttle application. It should only show this when you have the throttle pushed down; the SP6 only shows at idle or when you are coasting with no throttle pushed. It sounds like you may have had a glitch with the throttle position sensor. I'd suggest unplugging the Vitesse, plugging it back in, then recalibrating it.
P2138 is the code I got too. Luckily I was parked with the clutch pushed down. I'll try pulling and re-calibrating. PIA though. It gets one chance. Then Ill do what Boomer said.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
If this is more than one car where it's happened, and it seems to be, I can only wish that you don't run into or over someone or some thing.
Received 2,826 Likes
2021 C6 of the Year Finalist - Modified
I have a friend who put one of those in and it goofed his GS up with codes and other things...so he took it out...... no throttle mods for me.......
I was getting an error code and going into reduced power on mine also. I never experienced any engine surge. I talked to Ahmed at Vitesse. My problems have been related to placement of the electronics box (not the remote controller). Mine was tucked behind some carpeting. I moved it to a more open area and the problems disappeared. They came back and I noticed that the box had moved. Once I secured it in a good spot, it has performed correctly.
My car also experienced the "reduced engine power" when I had the Vitesse installed. I removed it, sent it back to Ahmed, and no problems since. Just not worth the chance of something happening as in the op's experience.
Received 1,136 Likes
I've been hesitating buying the controller for two years now because the rocket-science era electronics on these cars scares me, and I'm more comfortable leaving well enough alone.
Originally Posted by Bruze
I have absolutely no doubt that what you and dozens of other users say is true -- that it gets rid of the lag. The stock lag is real and it's annoying.
Try hundreds or more.
A lot of people leave their Corvettes all stock,my daughters Camry is stock. so...there you go
