Interior carpet
Interior carpet
need some help here all. Can some 1 explain the difference between cut pile carpet and the Truvette and truvette mass back carpet? Gonna replace my cashmere with black but no idea which is the original type.
Any help appreciated thank you.
these 2 r sold by Ecklers or does any 1 have a different source they have used to replace theirs?
This site gives you an idea of the differences. I was going to buy the complete set but ended up just dying the carpet black. It looks like the same product as Ecklers.
http://www.stockinteriors.com/AutoCa...d=5&ModelId=69
Don't know about the difference between the types of carpet, but chances are that if you have a Cashmere interior, your trim pieces are NOT BLACK!
Those trim pieces are most likely Ebony, not black, and if you order black carpet , it will look much too dark for your car.
Ebony to me is a dark grey, so if you want black, don't get ebony.
I'll have to look up what I bought from Ecklers. I did the same as you and changing a lot of my cashmere to black. The carpet install is tedious and just take your time. Measure several times and cut bigger. You can always trim off. It really sucks if you cut to much.
It's worth the change and you'll like it.
