ECS vs A&A
So the idea as of right now is...
V3 T Trim, 93 octane. Whatever power I can get safely. Hopefully 650whp.
I've spoken to two very reputable shops about the LS3 bottom end... both say I could hit 650whp on 93 for sure. 675-680 isn't out of the question.
650 whp is easily attainable with that set up. You can always add meth later. If meth is tuned right, it will have a fail safe built into the tune so that the car pulls timing if no meth is spraying. That way you don't motor on and melt a piston. The way it works with these things, you'll be back looking for a YSI!
I'm at 666RW with an A&A si 3.6", meth, full Z06/ZR1 pipes, and thinking dropping to 3.4, doing a flex fuel kit...and maybe a mild cam. I like my car sleeper/streetable/smogable, so don't want a big lopey cam. I do like the idea of stouter springs regardless.
BTW this belongs in FI subsection.
Forgot to come back to the thread!
Went with an A&A kit! V3 Ti along with the AEM Wideband Fail Safe Gauge! Measures AFR and boost. They can also program it to stop my pull if my fuel pressure isn't where it needs to be to save my motor. It should be going in within a month.
I've got a forged motor with 10:1 compression CP pistons, ARH headers with no cats, mild blower cam, Alky Control meth, with a 3.4 pulley that makes 750whp on a stingy Mustang Dyno at 11psi. The A&A kit is really well made and has excellent belt wrap. The install is very clean and drives like stock until you step on it. I really can't see any cons to the A&A kit.
Received 2,279 Likes
C4 of Year Winner (performance mods) 2019
Curious why you upgraded the springs and stuff, but not a cam, even an LS9 cam?
I like that the car is still stock cam and drives like stock when I'm not on it. Makes it very nice to drive on trips, and my wife doesn't mind riding in it at all if I want to take it out for date night. I've driven halfway across the country and it's just like driving it when it was stock. Of course if I want to play, all I have to do is give it some throttle...
I think about that too. A mild short block build. Nothing fancy or crazy. Something to spin the motor to 7200ish rpm and handle 900whp no problem. Then get one of those modules that stores tunes. Have a 600whp tune, 700whp tune, etc... hahaha
Does the car build any part throttle boost? I heard they don't. So it's gotta be night and day from driving around town and then laying into it.
Well I originally thought just the basic blower kit would be enough (600RWHP), and it was ... for about 1 year. Then did the 3.6 pulley and meth (670RWHP) and thought that would be enough ... which it was for about another year. Which led to the 3.4 pulley, at which point my tuner said he really would feel better if I upgraded springs. Yes, I'm sure I'm giving up power with the LS7 manifolds and stock LS3 cam, but honestly I've got more power than I can use now. If I upgrade anything else, it'll be to a good standalone with better traction control.
What did you make with the 3.4 pulley and meth?
So you have LS7 manifolds, LS9 cam, CAI, 3.4 pulley with which supercharger? You're making how much power?!
You must get awesome mpg too when cruising!
That's CRAZY! 11psi and 750whp on a Mustang Dyno?! That's like 800whp on a dynojet! That's gotta be good for 142+mph traps!! That's FLYING!
I wouldn't look to make more than 800-850whp. which is about where a Ti trim will max out, especially if running e85. Pushing a C6 past that gets expensive to maintain and will be much more difficult getting any traction on the street. Also, you'll likely need a YSI to reach that power level. You also won't need to spin the motor that hard to make power. I make peak power around 6600, but it stays steady to about 7k.
#33
LS7 manifolds, gutted cats, stock LS3 cam. Really only change to motor is upgraded springs, pushrods and rocker trunnions. Haven't redynoed but ran a buddy that dynoed a little over 700RW and we were dead even. Blower is A&A V3 Si with 3.4 pulley and dual nozzle Alky control kit. MPG is similar to stock when cruising.
#34
Received 1,194 Likes
St. Jude Donor '15
Though I don't have Bret tuning mine so maybe you've got me beat a little more
#35
#36
I don't run a boost gauge to monitor part throttle boost. With a centri sc it will make boost with rpms so don't know why you wouldn't go WOT.
Just wondering if it's all or not. Because I imagine going from 0 boost to lots of boost just by going WOT is crazy difference!
All this talk about these setups is killing me! Only shooting for 680 or so on 93 though.
#37
I'd go even further and say for a C6 that will primarily be for street use, I wouldn't go that far. 600-650RWHP is about all I'd want.
Yes, it is.
#38
I meant just for driving around town. When you're getting up to speed, passing someone, etc...
#39
When my car was at 600RW (pre meth with 3.8 pulley), I could hammer it to WOT and be ok. Once I dropped to the 3.6 and added meth, I could no longer do that for two reasons: 1) the loss of traction 2) I went through meth way too freaking fast
I actually miss that configuration a lot, if I wasn't doing 1/2 mile & mile events, I'd probably go back to it as it was more fun for street use.
#40
I have the same sickness as you do!
Car with nothing but basic blower kit was perfect for the street. Like you,I wanted to do racing events and had to turn it up.
