Factory Navigation
Factory Navigation
Hi guys I bought a factory navigation for my C6 a while now, I installed it and the anti theft was activated, I took it to a shop with a Tech 11 and had it programed to cleared the programmable vin, it started working fine, but the navigation is not working.
I did some checking and after speaking to a few friends I was told that the person who cleared the code accidentally cleared the map reader, I don't know if it is possible and if he did, all I know is I need it to work and will like to know if there are any way I can get it to work again by having it reprogram, can the same person who cleared the anti theft code use the same tool to get it working again. The head unit is not reading the navigation disc.
I do have the GM factory disc into the system and its a good working disc because I had it checked with a friend navigation system and its working, my system is saying ' no map data" Everything else is working fine, radio, xm radio, cd, but not the navigation.
Can anyone give me some advice on how I can resolve this problem, I really don't want to change out the factory system, hence the reason I bought this radio from a crash vette so I can still have the factory look with navigation added.
Race Car Tech
https://www.corvetteforum.com/forums...post1579261000
I'm assuming you installed the Gps antenna as well and not just the head unit right?
The laser diode head is not accessible in the OEM Nav system, so there is no way to clean it. I've even tried dissembling it, and still could not get to it.
Many of the factory nav units have had problems reading the map DVD, and it is a known issue with GM. I had mine replaced twice under warranty because of this problem. The last time the dealer told me that they had an "upgraded part number" for them now. He also told me they have seen this same problem with the same Nav system used in Cadillac and other GM models, and that it has been a big problem for GM. I suspect this had a lot to do with the new cars no longer using a DVD for the map data, and instead using physical memory.
I just did everything asked and still saying no map data, when I removed the disc its saying install disc, when I install the disc it is probably reading it because the message install disc is cleared but still saying NO MAP DATA, there are no stored destination and no stored home address.
Can it be something pertaining to the disc or the program to read the disc?
You could try compressed air to blow it out. Don't just use a can of air, but an air hose connected to a compressor cranked up to 80 PSI. I also use a CD lens cleaner made by Philips. It's basicially a dummy CD with mini brushes on it to wipe your laser lens clean.
My gut feeling is that it isn't a problem with the laser head getting dirty at all, but is more likely an issue with the output from it becoming too weak or dim to read a dual layer disc properly. Dual layer discs require a higher output laser to read them.
I am just about doing the same, I paid $500.00 for this unit used, paid $40.00 to clear the code and I just bought another Disc for $150.00 and is not about to put another dollar into this crap, its worst than depositing money into the Hairy Bank with no interest.
Only paying $500 is always a possibility. One thing also is if I'm not mistaken you have to match the nav with the car. I don't think they're all the same.
OP , can you borrow a disk .....the disks can go bad and be unreadable
Also , did you install a VSS wire ?
Dave
I had to replace mine years ago because I thought is was bad only to find out it was some of my home made cd's. I had to give my VIN to the dealer to assure correct radio.
Dave
Received 2,051 Likes
St. Jude Donor '13
Or possibly if they were going to install the new radio, do they need to input the VIN into the Tech2 to match the radio/car?
A lot of dealer parts guys automatically ask for your VIN because it will tell them what options are on the car so they get the correct parts. They can't know all of the options possibilities or running changes made during a model year.
I think you are correct, dealerships are just accustomed to asking for the Vin
Dave
