Led taillight help
Led taillight help
I installed 3157 led taillights and the flasher blinks fast. I then put a resistor on the first left blinker and no change. I then put a second resistor on without any change. Anyone have a solution for these?
Received 2,882 Likes
I think each bulb will need a resistor.
My Eagle Eye LEDs all have one.
Davidmcc (02-27-2017)
I put one on each bulb without luck. I tried jumping it across each yellow to black without results and then tried just on the yellows to see if that would work and nothing there either. I have heard about changing the flasher but if you do that then why would you need the resistors? My thinking is if power takes the least path of resistance then the resistor should go in-line or it would not do anything but that is notwhat I have seen on YouTube
You didn't get an instruction sheet with the LED's?
I bought led tail lights as well, each light had a module with a resistor that's 4 of them. Never caused any issues for me
LED's use less power than halogens, when your car realizes there is less power being drawn it assumes the light is burnt, and so it hyperflashes in an effort to notify you that a bulb is burnt.
Resistor uses up more electricity and converts it into heat and wastes it to trick the computer into thinking there are still Halogens by pulling the same voltage of a halogen.
Davidmcc (02-28-2017)
Every LED needs a resistor across it (not in series) so that the BCM computer sees the same CURRENT (not voltage) as the factory installed bulb. The LED DOES need a resistor in series to limit the current through the LED but that resistor is built into any LED that is rated for a voltage above about 1.5 volts.
BTW, it is the BCM that does all the flashing as well as a few hundred other things. No flasher and no manual timing advance on these new fangled cars.
Received 4,499 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I got the hyper flash taken care of but now the issue is the running lights are brighter then the turn signal, could it just be bad lights?
I haven't run into this or tested it, but are you sure you have the outer in the outside spot and the inner in the inside spot?
