C6 Front Spoiler(Air Dam) Replacement
The passenger side of the 3 piece unit was missing on my newly acquired C6 so I ordered a new 3 piece unit from West Coast Corvette. Parts arrived and I started to install. Removed the two end pieces which came off easy enough. Just 3 self tapping screws. The center section looks to be a bit more involved. Is there more to it than just the screws holding it in from the front. I put the new end pieces on but left the old center section which didn't line up exactly with the passenger side end piece. All this to ask this simple question.
How involved is replacing the center section?
Yea, there's a lot more to the center one. I think the specific methods of attachment, screws vs push pins, changed at some point, maybe '08, not sure, but the placement of the attaching points are the same.
Here are several prior discussions, read them all and I think you can get it. No pictures that I've ever seen.
https://www.corvetteforum.com/forums...r-dam-off.html
https://www.corvetteforum.com/forums...post1578783654
https://www.corvetteforum.com/forums...p-base-c6.html
https://www.corvetteforum.com/forums...post1574264376
thanks again.
You have to remove a few of the pins/screws that hold the bumper cover on to get the center piece out. It's a bit of work, but it does come out once those screws are removed.
