Torque Specs
Old 03-02-2017, 06:40 PM
Cedar
Cedar's Avatar
Default Torque Specs
Is there a torque spec on GS/ Z06 caliper pins? If so, does anyone know what it is?
Old 03-02-2017, 06:59 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
Here are the brake section torque values for a Z06
The following 2 users liked this post by 4SUMERZ:
Cedar (03-02-2017), devnull (03-02-2017)
Old 03-02-2017, 08:00 PM
User Omega
User Omega's Avatar
If you haven't already and you are just doing brakes do not remove the pins. Horror stories here of guys following the spec and the pins backing out destroying a wheel. Remove the caliper and install the padlets that way.
Cedar (03-02-2017)
Old 03-02-2017, 11:19 PM
Cedar
Cedar's Avatar
Thank you so much LV2TOUR and User Omega for the great info!
Old 03-04-2017, 01:05 PM
cclive
cclive's Avatar
This was my first thought also...many stripped heads and problems. Much easier to just remove the caliper...best to consider those pins to be permanent.
Cedar (03-04-2017)
Old 03-04-2017, 05:56 PM
SLOWRYDE
SLOWRYDE's Avatar
Agree with the above advise. I always just remove the Caliper and pop in the 6 padlets and reattach. Never had a problem with this method
Cedar (03-04-2017)
Old 03-04-2017, 06:46 PM
Cedar
Cedar's Avatar
Thanks cclive and SLOWRYDE! I was exploring all avenues. I'm going to change the color of my calipers from silver to red. I thought about powdercoating my calipers and the guy I talked to locally said they had to be completely disassembled to do that correctly. I'm leaning toward buying the G2 kit and doing them myself and saving a ton of money in the process. I was able to buy the GS/Z06 caliper decals cheap enough so that's probably be the way I go.
Thanks again for the replies, deeply appreciated!
Old 03-05-2017, 12:01 PM
cclive
cclive's Avatar
The paint will work fine...I did mine myself and it still looks the same 8 years later.
Cedar (03-05-2017)
Old 03-05-2017, 06:29 PM
Cedar
Cedar's Avatar
Thanks cclive! I was wondering how long it would last and you answered that.
Thanks again!
To Torque Specs
Quick Reply: Torque Specs
