Oil leak from filter
Hey guys, my car (08 C6) has a slow oil leak. I got under it and it looks like its coming from the oil filter seal. I added oil to the seal when I changed the oil months ago, also I hand tightened it at the time of oil change. It leaked a while ago and I tightened even more by hand and that seemed to fix the leak. Now it's leaking again and I'm pretty sure I can tighten it by hand a little more but I don't want to strip it. Also when I look for an oil filter torque wrench I don't seem to see how it will work with our filters as the wrench needs a bolt to grip. 22lbs of torque is what I read GM calls for. I'm not the best at DIY so any info would help Thanks.
Received 1,136 Likes
Occasionally I've had to snug one up a bit beyond hand tight with a wrench to stop a leak and have never had a problem getting it off.
Pro Mechanic
Received 3,952 Likes
You won't strip the threads by hand. The only problem with over-tightening is that they can be difficult to get off. However, in 50 years of changing oil I've never had that happen.
Received 1,596 Likes
With all the above. You might want to try a new filter, I have seen some that are just a Charlie hotel off and will not tighten up correctly.
When you changed the oil/filter, did you make sure the gasket from the old filter didn't get stuck on the engine? Now you're in a double gasket situation, not good. It happens.....
Thanks everyone. I'm pretty sure I took out the old gasket. I think I'll give it a good tighten by hand, if that doesn't fix it I'll just do another oil change. Thanks for the replies, much appreciated.
C6ROLLER (03-17-2017)
True or not, I heard this from an old GM tech. There was a bulletin put out at some point that stated to use only the AC Delco oil filter on our vettes. ????
I had the same dampness just behind the oil filter and thought it was a rear main starting to leak. The old guy said it's because of the oil filter I had on there. We changed it, used the AC Delco filter and it's as dry as can be.
Like I said, take it for what it's worth.
THIS!!! and yes it happened to me, seems to be Fram filters most of the time but have read of others...
The double gasket thing: I keep hearing about this (just since the internet age actually) and it is beyond my imagination as to how this happens. You have to be oblivious to the world around you to NOT NOTICE or even LOOK at the old filter as it comes off -- the gasket is very obvious and if it is NOT THERE it should be noticed by anyone with eyes.
Also, I always wipe the mounting surface off with a clean rag before installing the new filter, and it would be very obvious if there was a gasket stuck there.
Received 2,887 Likes
Yep 2 gaskets on filter, oil spewing everywhere.
Never say never. First and hopefully last time this ever happens to me.
At least it was HER car not mine.
Up till last month I would have agreed wholeheartedly with you. But when I changed the oil and filter in my wifes SUV I was lazy and just crawled under and went to work. Well my led worklight decided to die on me but smart as I am I kept going. Put in drain plug and took off the oil filter and dropped it onto the oil drain container as it was still hot. Slapped on the new filter, filled with oil. Good to go!! Started it up to circulate the oil to get a accurate level reading.
FWIW: In a half century of ALWAYS changing my own oil on cars, trucks, motorcycles, and tractors I have NEVER had a filter that was a problem to get off, and have NEVER had a gasket that didn't come off with the filter. I ALWAYS rub new oil on the new filter gasket. All of this stuff is just done by rote, for me anyways. I was probably taught -- or subconsciously picked up -- most of this stuff when very young, by older gearheads that I knew.
As I previously posted I only hand-tighten except on rare occasions when a bit of snugging with a wrench is necessary.
Oh well, the world spins . . .
