Replacement Battery Question
Old 03-20-2017, 07:42 PM
rn53982
rn53982's Avatar
Default Replacement Battery Question
Good evening all and please excuse the ignorance of my question, as I am new to the C6 ownership world.
Just bought my 2009 about 5 weeks ago and have only got to drive it a few times due to crappy weather. Went out this weekend to find that the battery is dead, which after reading up I see is a major issue with these vehicles not being driven.
From the records of the car, it looks like the battery is the original OEM AC Delco that came installed in the car, so I plan to replace with a new battery and purchase a CTek 3300 Tender unit.
My question, does it really matter if I replace the battery with the same OEM AC Delco, or is any battery fine as long as it meets the same specs? Likely a silly a question and I would not give it a second thought on the daily driver sedan, but I thought it was worth asking. Calling around to AutoZone, O'Rileys, Advance, and Napa and none carry the AC Delco battery, so I am guessing I would have to purchase from the dealer, which I don't mind if it is recommended.
Thanks in advance and my apologies for the "noob" question.
Old 03-20-2017, 07:56 PM
TorchRedFred
TorchRedFred's Avatar
Received 1,636 Likes on 1,121 Posts
You can use any brand battery. I went with a Die-Hard battery for my 2012 GS. Just check in the manufacturer's booklet for which specific battery you need or ask a someone that works there to look it up. Also you can check any battery manufacturer's website for which exact model is specific to your car.
Old 03-20-2017, 07:59 PM
EVRose
EVRose's Avatar
Except for Optimas they are all basically the same and made by the same company. I've had a Walmart battery for the past 3 years with a tender always attached and it's been fine.
Old 03-20-2017, 08:13 PM
rn53982
rn53982's Avatar
Thanks. I figured I was overthinking it, but never hurts to ask. From what I have read, these cars eat up batteries if not driven consistently or tendered.
Old 03-21-2017, 02:10 PM
buck fever
buck fever's Avatar
I just installed a new battery in mine on Saturday. Overall it was a pretty easy job. I went with the Autocraft Gold battery from Advance Auto. After returning the old AC Delco along with their tax madness sale, I paid $94.00.
The Gold battery scored very high on online reviews and is apparently made by the respected company Johnson Controls. I'm happy with it.
Old 03-21-2017, 03:17 PM
rn53982
rn53982's Avatar
Cool thanks for the info. After some quick research it looks like Johnson Controls many other of the popular battery choices as well. I have an Advance close and figured that's what I would go with. In addition, just purchased a CTEK 3330 US Multi unit to hook up when the car is not in use to hopefully avoid the battery drain in the future.
Old 03-21-2017, 03:28 PM
diitto
Support Corvetteforum!
diitto's Avatar
If your battery truly was original in an '09, that's pretty good duration. Mine failed in my 2012 GS at about 4 years (bought the car new) and I was told that was pretty typical. I researched a lot of batteries but since I was going to do the install myself in my garage, I chose to go ahead and buy the exact AC Delco replacement from my local dealer. I found the price to be pretty reasonable at $108 plus tax plus an $11 core charge which they gave me back when I brought the old battery back to them. There was a good YouTube video of someone replacing the exact same Delco battery in a car similar to mine which showed me just how to turn it to best drop it in to place. I just chose to keep it simple and replace with precisely the same shape and size that came out, meaning the same AC Delco battery. At $108 plus tax at my dealer. Just FYI. bob
Old 03-21-2017, 08:59 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
I'd agree; you can choose just about any batt. And, yes, also to the Ctek 3300. Don't be "embarrassed" to put it on your batt. in summer or winter. As the saying goes, it can't "hoit" to use it anytime you're going to let the car sit for awhile. For me, the easy way to connect it up was through the driver's door window into the cig lighter which was always hot. Console interior plug in is also hot, but more of a hassle.
Old 03-21-2017, 09:38 PM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
I bought an Autozone Platinum battery when the AC Delco died in my '09. It's an AGM (absorbed glass mat) battery like Optima. I've had it in the car for 3 years and it's still going strong. It was fairly expensive but it also lasts a long time and has a good warranty, so the cost is really not an issue
Old 03-21-2017, 10:31 PM
ruxvette
ruxvette's Avatar
Received 3,601 Likes on 2,334 Posts
2016 C6 of Year Finalist
Originally Posted by rn53982
...and purchase a CTek 3300 Tender unit...
Cteks certainly work. A lot of folks on here, me included, use the Schumacher from Walmart. About $20.
Old 03-24-2017, 07:16 AM
C6ToGo
C6ToGo's Avatar
Received 1,108 Likes on 690 Posts
Agree. Advance AP's Autocraft is a good battery.
Buy online with coupon code "savings" to get 30% off. Choose "pick up in store".
Old 03-24-2017, 09:09 AM
Scuba Ghost
Scuba Ghost's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Your OEM was an AC Delco and lasted 8 years. Why not buy another AC Delco?
Old 03-24-2017, 09:15 AM
RichKiss
RichKiss's Avatar
Just remember to look up how to re-calibrate your windows. You will need to. Its in your manual and here as well
Old 03-24-2017, 09:25 AM
Jughead
Senior Member since 1492
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
autozone duralast $100
Old 03-24-2017, 10:47 AM
1bdvet
1bdvet's Avatar
Received 4,499 Likes on 3,586 Posts
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Last battery on my C4 came from Walmart, and it was great battery, the C6 running on OEM.
Old 03-24-2017, 11:03 AM
Kenny94945
Kenny94945's Avatar
Delco fits exactly, appears as unaltered (show points?).
Yes OEM Delco can last 7 years, yet in my experience all the Delco replacements go 3 and storage capacity drops (length of radio on without engine on), yet always has enough to crank.
So, purchase Johnson Controls, Deka manufacturor brands (relabeled Autozone Sears etc) exceeding OEM spec from anywhere you find covenant.
+ 1 for Tenders.
Old 03-24-2017, 11:06 AM
LS WON
LS WON's Avatar
To Replacement Battery Question
Old 03-24-2017, 11:08 AM
LS WON
LS WON's Avatar
My original AC Delco battery from factory was a 6 yr. warranty battery that lasted 12 years on my 2005. I just replaced it with another AC Delco battery.
Old 03-24-2017, 11:15 AM
Cuckoo
Cuckoo's Avatar
My battery on my 2011 GS just pooped out 2 days ago. I had a feeling it was going because of a weak start last week when I washed it. I bought my GS preowned last August and have only put 1200 miles on it. It sat a lot the past few months because of the rainy weather we had here in So Cal. Wednesday I had just bought a Shumacher SP3 tender to hook up and the battery was dead right then. The battery was an AC Delco. At 7 yrs old I doubt it was original but you never know. I was ready to go to the local chevy stealership to pick up another one but read a few posts about just getting an Autozone battery because if it fails there are usually Autozones all over the place to get a replacement.
Loonggg story short I went with the Autozone Duralast battery, about $25 cheaper and it fit perfect.
The Schumacher sp3 was only $32 & comes with all the hook ups and an extender cord was $9, seems like it will do the job.
Old 03-24-2017, 11:30 AM
need-for-speed
need-for-speed's Avatar
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
I keep my C6, my Camaro, and my Silverado on Battery Tenders because I don't drive them enough. One of my batt tenders died (Lightning). Does the Schumacher have a "brain" / voltage regulator like the batt tender? i.e. Not just a trickle charger?
Quick Reply: Replacement Battery Question
