Setting the radio to 0
Old 03-22-2017, 08:33 AM
bucwheat
bucwheat's Avatar
Default Setting the radio to 0
Anyone know how to set a radio with nav to 0,I'm trying to get my radio serial number and the owner manual says to set the radio to 0.
Old 03-22-2017, 08:46 AM
shakinrock
shakinrock's Avatar
If you are referring to your XM radio ID go to either channel 0 or 1 (I forget which one) while tuned into XM.
bucwheat (03-22-2017)
Old 03-22-2017, 08:55 AM
rkj427
Pro Mechanic
Support Corvetteforum!
rkj427's Avatar
Received 3,952 Likes on 2,470 Posts
another option would be to take your VIN to your local GM dealer and have them run a VIS report...........Vehicle Information Service
typically provides ALL vehicle build info. including options, warranty information, and radio ID information..............
FREE OF CHARGE, just takes them 5 - 10 minutes to do so..........
Old 03-22-2017, 09:23 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
You just have to keep pushing the scan button until you get down to zero. This is easy if you don't have a subscription because 0 and 1 (Preview) are all you get. With a subscription the easiest way I've heard that works is to go to the lowest number preset you have and then push and push and push ... Since I have never had a subscription except all the free ones they keep having, I don't know but you might try parking in a garage where you can't get a signal to make it think you don't.
I forgot to add, if you push and push and end up cycling, you have set a category. Change categories.
Old 03-22-2017, 01:41 PM
bucwheat
bucwheat's Avatar
Thanks so much for the help.
Old 03-23-2017, 08:06 PM
ByRiver
ByRiver's Avatar
I can't believe you have never received an email from Sirius offering you 5 months for $25. I get them at least twice a month. In the email they list your Radio ID.
To Setting the radio to 0
Quick Reply: Setting the radio to 0
