2005-2007 C6 Corvette Halltech Venom II @ RPI Designs
Old 03-24-2017, 02:29 PM
RPIDON
Platinum Supporting Vendor
RPIDON's Avatar
Default 2005-2007 C6 Corvette Halltech Venom II @ RPI Designs
This Halltech C6 Venom II for the C6 Corvette Base Car with the LS2 motor will help your car run its best. Its design will let you bolt on 15 RWHP/12 lbs ft torque with its all-new C6 Corvette LS2 intake design. This C6 Corvette intake is made from the same mold as the Killer Bee II that dynoed +15 HP/+14lbs-ft. on the Katech Engine Development Superflow dyno. The same huge high flow K&N Filter will flow over 1250 cfm and feeds over 900 HP easily. This system uses the stock wiring and MAF sensor for direct bolt on power that will not void your warranty. It comes with Halltech's Beehive Heat Shield to isolate the filter from engine heat and capture cold air with optional cutouts for cold air induction.
The new filter has a positive stop built into the flange to eliminate the step ingress to the bridge for a smoother flow. It also has the latest technology for high-velocity flow through the filter with a bellmouth designed flange. Please note this intake is not compatible with 2008 and beyond models!
Estimated HP increase is 9-15 HP over the stock airbox. Your C6 Corvette intake and exhaust system are two of the easiest ways to add Horsepower to your C6 Corvette. Don't skip on either one, get the best you can afford.
Fitment: 2005, 2006, 2007 Corvette
Item # 301-005
Website Link : https://www.rpidesigns.com/shop/item...tech-venom-ii/
__________________
Quick Reply: 2005-2007 C6 Corvette Halltech Venom II @ RPI Designs
