12V Switched Source From Fuse Panel
Old 04-06-2017, 11:36 PM
crusher1
crusher1's Avatar
Default 12V Switched Source From Fuse Panel
Hi Guys,
I am looking for another 12V switched source only when the igniton is on.
I have used 3 already circled in red in the pic with a fuse tap. Is there a 4th available?.....I cant seem to find another
Old 04-07-2017, 12:47 AM
JJLAI724
JJLAI724's Avatar
If your not drawing a lot of voltage you can use one of these add a circuits.
Amazon Amazon
Z31/ZO6 GUY (02-14-2024)
Old 04-07-2017, 06:38 AM
crusher1
crusher1's Avatar
Yes that's what I am using already. I used 3 fuse taps (add a circuit) in the locations I circled in the pic. I am looking for a 4th location. Any ideas??
Old 04-07-2017, 07:26 AM
FAUEE
FAUEE's Avatar
Received 4,449 Likes on 2,803 Posts
Why not reuse one of those?
Old 04-07-2017, 09:24 AM
jaki30
jaki30's Avatar
I don't have the manual, but, maybe the tonneau release could be ignition on?
Old 04-07-2017, 09:49 AM
crusher1
crusher1's Avatar
I checked that already and it's 12v always on. Thanks for the suggestion though.
Want to hook up my npp in a box to a 4th switched 12v in the fuse panel . Anyone ?
Old 04-07-2017, 09:54 AM
JJLAI724
JJLAI724's Avatar
What about the heated seats or reverse lamps? You might need a volt meter to probe and see what's hot with the ignition off, then do a check with the ignition on.
Old 04-07-2017, 10:19 AM
crusher1
crusher1's Avatar
Yeah just did that and both are showing constant 12v all the time
There must be at least one more extra fuse in here with just 12v switched..unless the 3 I used already is the limit for this fuse panel?
Old 04-07-2017, 10:52 AM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
HVAC should be switched
Old 04-07-2017, 10:54 AM
EVRose
EVRose's Avatar
Windshield wipers.
Old 04-07-2017, 02:06 PM
FAUEE
FAUEE's Avatar
Do yourself a favor and run a new power wire from the battery, and use one of the 3 wires you already tapped as a trigger to activate a relay for this. Then you'll have a nice switched power wire to do what you want with.
Silver c6 z-51 (12-12-2021)
Old 04-07-2017, 08:02 PM
crusher1
crusher1's Avatar
Thanks sevinn, that worked. the ISRVM/HVAC fuse only puts out 12v with the ignition in the on position
Thanks to all also for chiming in
Old 04-07-2017, 08:05 PM
sevinn
sevinn's Avatar
Old 12-23-2017, 05:54 AM
sboblett
sboblett's Avatar
I just installed my NPP this way on the 2A Cruise fuse. It is switched on when the ignition is on but is not hot when just the accy is on and works fine so far. Does anyone have a reason not to use this fuse?
Old 12-23-2017, 08:43 AM
madsonp
madsonp's Avatar
Received 1,757 Likes on 1,169 Posts
What all do you have hooked up to this thing where you need so many connections ?
Old 12-23-2017, 10:02 AM
Mojo 97 Vett
Mojo 97 Vett's Avatar
Old 12-23-2017, 10:05 AM
sboblett
sboblett's Avatar
I have a back up camera attached to my factory radio / nav display and a mild to wild exhaust vacuum switch.
To 12V Switched Source From Fuse Panel
Old 12-23-2017, 01:18 PM
madsonp
madsonp's Avatar
For the two cameras on mine (front and rear), I just tapped into the power lead of the stereo at the stereo (I installed a Pioneer aftermarket system in mine). You probably could have done the same on yours.
Old 11-21-2021, 02:33 PM
ncnmra
ncnmra's Avatar
I realize this is an ancient thread, my apologies for ressurecting. I'm looking for a switched power for some aftermarket heated seats I'm installing. To my surprise, the EXH MDL and HTD SEAT / WPR RLY fuses are hot even when the car is off. Am I missing something?
Old 11-21-2021, 02:53 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
There are times when one might want to use/adjust the seat, or use the wipers, with the ignition off. Regardless, there is no power use until you demand it through the switches. You can use the Heated Seat output for your aftermarket heated seats, right? No power will be consumed until you operate the switches on your seat. I am weak on electronics, but that makes sense to me.
Quick Reply: 12V Switched Source From Fuse Panel
