Brake rotor size?
Brake rotor size?
I tried to do something to get the possible front rotor size, but it looks like that might of totaly not worked, maybe one of you will have better luck.
Even if the front rim was a big 19" or 20" I expected the rotor to be larger. Aren't the OEM C5 calipers already 13"?
Rim Diameter = ~204 pixels
Rotor Diameter = ~137 pixels
Rotor is 67.15% of rim
17" Rim = 11.4"
18" Rim = 12"
19" Rim = 12.75"
20" Rim = 13.43"
**EDIT**
I thought maybe the angle was throwing me off so I did another picture.
Rim Diameter = ~202pixels
Rotor Diamter = ~133pixels
Same really.
***UPDATE***
I did the rear wheel with the suggested method below.
The lug pattern I found for a C5 is 5x120mm. The green circle you see in this pic is 120mm in diameter.
~50 Pixels = Lug Pattern = 4.72"
~125 Pixels = Rear Rotor = 250% = 300mm diameter = 11.8"
~210 Pixels = Rear Rim = 420% = 504mm diameter = 19.8"
If I do it the way I did the first two pictures I get....
Rotor = 60% of Rim
19" Rim = 11.4" Rotor
20" Rim = 12" Rotor
21" Rim = 12.68" Rotor
[Modified by scorp508, 5:12 PM 11/19/2003]
17" Rim = 11.4"
18" Rim = 12"
19" Rim = 12.75"
20" Rim = 13.43"
**EDIT**
Same really.
***UPDATE***
Rotor = 60% of Rim
20" Rim = 12" Rotor
Re: Brake rotor size? (scorp508)
Do you think that the fact that the rim had no lip is throwing you off? How do they measure wheel size? Is it the inner diameter? If so your pixel count would be smaller, I think.
The C5 rotor is 12.75". So if you calculate it to 12.75" I would think you are right, has been no firm information that this will change.
Re: Brake rotor size? (ivan111)
Scorp,
What if you used the distance between the lugs as the point of reference, and then measured the rotors with that distance. I don't have my car with me today, but if someone would measure between the center of the lugs that might be a little more accurate for measuring the rotor. Worth a try.
Re: Brake rotor size? (Falcon)
Re: Brake rotor size? (rgregory)
Re: Brake rotor size? (BillY2KFRC)
Can anybody calculate the rear wheel size?
18" front and 19" rear wheel size on the C6. My guess is the rotor is the same size as the C5, but will be bigger on the Z06 version.
Re: Brake rotor size? (Rippied Z06)
See my first post for an update.
I am leaning towards 19" front & 20" rear rims. The rotors look to be 12.8" front and 12" rear which is identical to the C5.
[Modified by scorp508, 5:22 PM 11/19/2003]
☠☣☢ Semper Ebrius ☢☣☠
Here's some help, Scorp. The C6's wheelbase is known to be 105.7"
I measured pixels from the center of one wheel to the center of the other.
Now I know that one inch is approximately 11 pixels.
Using that, I measured the diameter of the wheels and came up with 19" front and 20" rear.
Screwing around with the image some more, I come up with a 12" rotor in the rear and a 12.8" rotor in front.
[Modified by Scissors, 6:11 PM 11/19/2003]
Re: Brake rotor size? (Scissors)
Also, using the wheelbase to calculate pixel-to-inch conversion, I measured the overall length.
The C5 is 14' 11.7"
The C6, from what I can gather, is 13' 4.5"
So either my measurement is off, or the C6 lost a lot of overall length, or both.
:cheers:
The C5 is 14' 11.7"
:cheers:
Length is only supposed to be about 5 inches shorter than C5. Wheels will be 18 front and 19 back . 245/18 and 285/19 so I've read.
