Is there a key hole for ignition?
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Look like none to me. Just a button :cool:
http://www.motortrend.com/multimedia/wallpaper/112_0401_corcorvette C6_gal/
Click on "World Debut: 2005 Chevrolet Corvette Wallpaper Gallery"
[Modified by mike76002, 1:19 PM 1/6/2004]
[Modified by mike76002, 1:22 PM 1/6/2004]
Re: Is there a key hole for ignition? (mike76002)
Yep, button only.
The "key" is a proximity transmitter similar to a Mobil Speed Pass that activates the car when within one meter of it. You just leave it in your pocket, open the door, get in, step on the brake (auto) or clutch (manual), and push the button to start.
They explained it to us at the LA Auto Show yeaterday.
[Modified by adamsocb, 11:30 AM 1/6/2004]
Cool, but it kinda takes the traditional phallic symbolism out of things.
Now it's more like "check out what's in my pocket baby".
Not to give anyone any ideas but that could potentially open the door for a new string of car theft...thief breaks into the car, ducks down and waits for owner to approach and when they get within one meter he/she hits the button and leaves. :steering:
I'm assuming that breaking into the car in the first place would activate the security system preventing any of this from happening?
Location: Recovering from a tragic boating accident in Jacksonville Fl
CI 5-6-7-8-9-10 Vet
Re: Is there a key hole for ignition? (Registered)
Re: Is there a key hole for ignition? (LT1LS1)
I don't think the car will start until the fob is actually within the car.
Re: Is there a key hole for ignition? (RedHot)
Suppose you've walked up to the passenger door and it unlocks to load something on the curb side- what's to prevent a knowledgable thief from jumping in the driver's side and starting the car and taking off ? Would the motor shut off if the car is driven , say, more than 20 feet away from the transponder in your pocket to prevent this ?
[Modified by usroute66 MKW, 12:41 PM 1/6/2004]
Re: Is there a key hole for ignition? (2KFRC5)
I'm sure GM has thought up much more scenarios than any of us can and has taken the appropriate actions to prevent them from occurring. I'd say if anything the C6 is the most theft-proof Corvette yet. Everything is now electronic and your average joy riding car thief won't be able to just drill out the door as in the C5 and just bypass a resistor pellet. The car is now a much more difficult target.
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Re: Is there a key hole for ignition? (usroute66 MKW)
:chevy
This whole thing makes me a bit nervous! Computers have a tendency to fail, and remotes CERTAINLY do. For instance….it has happened to me twice (in probably 2 years) where the tire pressure sensors disappear while driving for a few minutes (and the car tells me I have to get them checked) – then they just come back on their own (and once after a re-start)! Or now, how my last working key fob (the other will constantly lock and unlock the car repeatedly as it is stuck in passive mode) requires that you be right next to the driver door for it to work (new batteries don’t help). And everyone knows about the great column lock conspiracy that has C5 owners praying when they put their key in the ignition.
Anyhow…don’t get me wrong. I like a great deal of what the C6 has to offer (some of my styling hesitations may be done away with by actually seeing the thing). But, these kind of things freak me out a bit. No key at all…completely relying on transmitters? Cool concept, but dang that makes me a little nervous! What kind of “column lock” stories do you think the C6 forum will be filled with in years to come!!!! Hopefully none! Fingers crossed!!!
[Modified by Geoff McD, 3:50 PM 1/6/2004]
[Modified by Geoff McD, 3:51 PM 1/6/2004]
Former Vendor
Re: Is there a key hole for ignition? (vetteinsider)
No, the engine would not shut off when it is 20 meters away from the fob. But, once the engine is shut off it would not restart with the proximity fob.
:chevy
:chevy
Does it have battery check up? Since the car won't start if the fob battery goes north :D
If the system is the same as the caddy's, here are some details. This does not answer all of our questions, though, but it is interesting.
http://www.cadillac.com/cadillacjsp/...eature=keyless
The car will start only if the FOB is in the vehicle.
Received 5,188 Likes
Sorry, but it's all too, too SILLY! :yesnod:
I read somewhere that there are manual door releases in the trunk, so if your battery dies in the fob, you're not stranded :D
Re: Is there a key hole for ignition? (need-for-speed)
the Sig-Saur model 229 .40 caliber in my pocket :jester
Now, just relax! The system uses technology that has been in this car for several years. The ignition is controlled by the column lock controller so you have real "redundancy" in the operating system. It will NEVER fail, honest! :lolg:
Re: Is there a key hole for ignition? (mikegoat)
" Keyless Go" has been problem plagued on recent Mercedes models that lotsa owners are really bent out of shape . Do a search on MBWorld or BenzWorld ... OTOH .... maybe don't . :eek:
Cruise-In II Veteran
Cruise-In III Veteran
[Modified by kewlbrz, 11:51 PM 1/6/2004]
