GM Auto Book Updates for the C6
Former Vendor
St. Jude Donor '06
Here is the Convertible Info.
2005 Chevrolet Corvette
1YY67 2dr Convertible
VEHICLE SUMMARY: GMS
Base Vehicle: W/A
Total Options: W/A
Advert/Adjustments: W/A
Destination Charge: W/A
Total Price: W/A
VEHICLE SUMMARY: MSRP
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
Effective Date: 4/12/04
STANDARD EQUIPMENT
<<< NOTE >>>
**ALL STANDARDS ARE 2005 UNLESS OTHERWISE NOTED**
<<< MECHANICAL >>>
Engine, 6.0L LS2 V8 SFI (400 HP [298.3 kW] @ 6000 rpm, 400 lb.-ft. [542.8 N-m @ 4400 rpm)
Transmission, 6-speed manual, short-throw (Includes (GU6) Axle, 3.42 ratio.)
Axle, 3.42 ratio, limited slip (Standard with (MN6) Transmission, 6-speed manual)
Rear wheel drive
Active handling, improves traction and enhances vehicle stability
Traction control, all-speed
Engine access, rear opening hood, includes underhood lamp
Suspension, 4-wheel independent, includes transverse fiberglass leaf springs
Tires, front P245/40ZR18, extended mobility, Eagle F1
Tires, rear P285/35ZR19, extended mobility, Eagle F1
Wheels, 5-spoke aluminum, 18" x 8.5" (45.7 cm x 21.6 cm), front and 19" x 10.0" (48.3 cm x 25.4 cm), rear
Steering, power, speed-sensitive, rack and pinion
Brakes, 4-wheel antilock, 4-wheel disc
Fuel capacity, approximate, 18 gallon (68 liters)
Exhaust, aluminized stainless-steel
Exhaust outlets, chrome-plated tips
<<< EXTERIOR >>>
Convertible top, manual folding, includes glass rear window with integral defogger
Headlamps, bi-functional, Xenon, high-intensity discharge, includes automatic exterior lamp control
Fog lamps, front, integral in fascia
Daytime running lamps
Mirrors, outside rearview, power, heated, body-color
Glass, Solar-Ray light tinted
Wipers, intermittent, front
<<< INTERIOR >>>
Seats, front Sport bucket with perforated leather seating surfaces, includes back angle adjustment, adjustable lumbar and side bolsters (Includes (AJ7) Air bags, frontal and side-impact, driver and front passenger)
Seat adjuster, power, driver 6-way
Seat adjuster, power, front passenger 6-way
Console, floor, lockable, includes 2 covered cupholders, ashtray with cigar lighter, auxiliary power outlet and CD storage
Floormats, carpeted
Steering column, manual, Tilt-Wheel
Steering wheel, leather-wrapped
Instrumentation, analog, electronic, includes Driver Information Center with 2 line display
Tire Pressure Monitor System, air pressure sensors in each tire pressure display in Driver Information Center
Oil life monitoring system
Door locks, power, programmable, includes lockout protection
Windows, power, includes driver and passenger express-down
Cruise control, electronic with set and resume speed
Theft-deterrent system, push button start, immobilizer and audible visual alarm
Keyless Access, with push-button start, includes 2 remote transmitters which enable automatic door unlock and open by touching door switch
Ignition, keyless, engaged with push button start
Trunk, rear, includes remote release
Trunk release, push button open
Defogger, rear-window, electric
Air conditioning, dual-zone, automatic, includes individual climate settings for driver and right front passenger, automatic climate control and outside temperature display
Air filtration, includes pollen filter
Sound system, ETR AM/FM stereo with CD player and MP3 playback, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume, Theftlock and (U66) Sound system feature, 7-speaker system
Antenna, integral, hidden
Mirror, inside rearview, manual day/night, includes dual reading lights
Visors, illuminated vanity mirrors, driver and front passenger
Lighting, interior, courtesy, cargo and glovebox
Storage, includes lockable glovebox, center console and 2 rear compartments with covers
Cargo convenience net, in rear compartment area
<<< EPA FUEL ECONOMY RATINGS >>>
City 19/hwy 28 (5.7L engine/6-speed manual trans) (2004)
City 18/hwy 25 (5.7L engine/4-speed auto trans) (2004)
<<< SAFETY >>>
Air bags, frontal and side impact, driver and front passenger (Always use safety belts and proper child restraints, even with air bags. See the Owners Manual for more safety information.)
Air bag, shut-off switch, front passenger
Lower Anchors for child safety seat
SELECTED OPTIONS
<<< EMISSIONS >>>
FE9: EMISSIONS, FEDERAL REQUIREMENTS
GMS: GM Emp Stock Purch.: W/A MSRP: W/A
<<< ENGINE >>>
LS2: ENGINE, 6.0L LS2 V8 SFI (400 HP [298.3kW] @ 6000 rpm, 400 lb.-ft. [542.8 N-m] @ 4400 rpm) (STD)
<<< TRANSMISSION >>>
MN6: TRANSMISSION, 6-SPEED MANUAL, SHORT-THROW (Includes (GU6) Axle, 3.42 ratio) (STD)
<<< PREFERRED EQUIPMENT GROUP >>>
1SB: PREFERRED EQUIPMENT GROUP, includes (UV6) Head-Up Display, (UG1) Homelink transmitter, (AAB) Memory Package, (DD0) Mirrors, inside rearview with compass and driver outside rearview, auto-dimming, (KA1) Seats, heated, driver and passenger, (US9) Sound system, ETR AM/FM stereo with 6-disc, in dash CD changer, MP3 playback, (N37) Steering column, power telescopic, includes manual tilt
<<< SEAT TYPE >>>
AQ9: SEATS, FRONT SPORT BUCKET WITH PERFORATED LEATHER SEATING SURFACES, includes back angle adjustment, adjustable lumbar and side bolsters (Includes (AJ7) Air bags, frontal and side-impact, driver and front passenger.) (STD)
<<< SEAT TRIM >>>
__3: HIGHWEAR NUANCE LEATHER SEAT TRIM (STD)
<<< PAINT >>>
___: SOLID PAINT (STD)
<<< TOP COLOR >>>
35T: BEIGE CONVERTIBLE TOP COLOR
<<< RADIO >>>
US9: SOUND SYSTEM, ETR AM/FM STEREO WITH 6-DISC, IN DASH CD CHANGER, MP3 PLAYBACK AND (U65) SOUND SYSTEM FEATURE, BOSE PREMIUM 7-SPEAKER SYSTEM, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume and TheftLock (Requires 1SB Preferred Equipment Group.)
<<< WHEELS >>>
QG6: WHEELS, 5-SPOKE ALUMINUM, 18" x 8.5" (45.7 CM x 21.6 CM), FRONT AND 19" x 10.0" (48.3 CM x 25.4 CM), REAR (STD)
<<< ADDITIONAL OPTIONS >>>
UV6: HEAD-UP DISPLAY, includes dot-matrix readouts for street mode, track mode with g-meter, vehicle speed, engine rpm, and readings from key gauges including water temperature and oil pressure (Requires 1SB Preferred Equipment Group.)
UG1: HOMELINK TRANSMITTER, includes garage door opener, 3-channel programmable, located on driver visor (Requires 1SB Preferred Equipment Group.)
AAB: MEMORY PACKAGE, 3 driver settings, remembers "presets" for 6-way power seat, outside mirrors, climate control, radio presets and telescoping steering column (Requires 1SB Preferred Equipment Group.)
Here is the Coupe
1YY07 2dr Cpe
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
STANDARD EQUIPMENT
<<< NOTE >>>
<<< MECHANICAL >>>
Rear wheel drive
<<< EXTERIOR >>>
Roof panel, removable, 1-piece, body-color
<<< INTERIOR >>>
Seats, front bucket with leather seating surfaces, includes back angle adjustment
Floormats, carpeted
Hatch release, push button open, includes power rear hatch latching
<<< SAFETY >>>
Air bags, dual-stage, frontal, driver and front passenger (Always use safety belts and proper child restraints, even with air bags. See the Owners Manual for more safety information.)
SELECTED OPTIONS
<<< EMISSIONS >>>
<<< ENGINE >>>
1SA: PREFERRED EQUIPMENT GROUP, includes (AJ7) Air bags, frontal and side impact, driver and front passenger, Cargo convenience net, in rear compartment area, (D42) Luggage shade, (AG2) Seat adjuster, power, front passenger 6-way, (AQ9) Seats, front Sport bucket with perforated leather seating surfaces
<<< SEAT TYPE >>>
AQ9: SEATS, FRONT SPORT BUCKET WITH PERFORATED LEATHER SEATING SURFACES, includes back angle adjustment, adjustable lumbar and side bolsters (Includes (AJ7) Air bags, frontal and side-impact, driver and front passenger.) (Requires 1SA or 1SB Preferred Equipment Group.)
<<< SEAT TRIM >>>
<<< PAINT >>>
<<< RADIO >>>
US8: SOUND SYSTEM, ETR AM/FM STEREO WITH CD PLAYER AND MP3 PLAYBACK, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume, TheftLock and (U66) Sound system feature 7-speaker system (STD) (Requires 1SX or 1SA Preferred Equipment Group.)
<<< WHEELS >>>
AJ7: AIR BAGS, FRONTAL AND SIDE IMPACT, DRIVER AND FRONT PASSENGER (Always use safety belts and proper child restraints, even with air bags. See the Owners Manual for more safety information.) (Requires 1SA or 1SB Preferred Equipment Group.)
Prices not included yet.
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
STANDARD EQUIPMENT
<<< NOTE >>>
<<< MECHANICAL >>>
Rear wheel drive
<<< EXTERIOR >>>
<<< INTERIOR >>>
Floormats, carpeted
<<< SAFETY >>>
SELECTED OPTIONS
<<< EMISSIONS >>>
<<< ENGINE >>>
<<< SEAT TYPE >>>
<<< SEAT TRIM >>>
<<< PAINT >>>
<<< TOP COLOR >>>
<<< RADIO >>>
<<< WHEELS >>>
Here is the Coupe
1YY07 2dr Cpe
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
Base Vehicle: W/A
Total Options: W/A
Total Price: W/A
STANDARD EQUIPMENT
<<< NOTE >>>
<<< MECHANICAL >>>
Rear wheel drive
<<< EXTERIOR >>>
<<< INTERIOR >>>
Floormats, carpeted
<<< SAFETY >>>
SELECTED OPTIONS
<<< EMISSIONS >>>
<<< ENGINE >>>
<<< SEAT TYPE >>>
<<< SEAT TRIM >>>
<<< PAINT >>>
<<< RADIO >>>
<<< WHEELS >>>
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '03 & '06
Re: GM Auto Book Updates for the C6 (Rick @ Les Stanford)
Thanks Rick...
Let us know when you get those Prices..
Rick,
Does this mean that dealers start placing customer orders into the system starting tomorrow April 12?
