Dang - 1st problem already
Originally Posted by djhartm
While driving around Napa yesterday, I noticed the message "Service Fuel System" displayed on the DIC. The message quickly went away, and I hoped it was a fluke.
Unfortunately, the message came back, and this time I noticed the fuel-gauge would go to empty. Then it would return to normal and the message would clear. Also the check-engine light stayed on.
So, I'm guessing a loose connection or a short in the fuel-gauge, or a defective gauge. I'll try & get a service appointment tomorrow.
1 week old & 622 miles.
I think it was simply a bad part. I now have close to 4k miles & have been using the same premium gas from Safeway, Valero, Arco, 76, etc., as I was initially using from the same stations.
The problem has not resurfaced.
Originally Posted by sah5150
I think this FSU problem should be front and center in the Known Issues in the FAQ. We now have 3 confirmed cases...
Steve
Steve
Originally Posted by C5inNY
This is a common problem across mutiple car makers and hits cars over many model years. It's the gas. Gas only comes from a few refiners in any area. All it takes is one mistake and a lot of gas gauges go in the crapper. This happened in NW PA this last summer and the PA Attorney General opened a hot line to handle all the complaints since it was costing owners several hundred dollars each to get gauges repaired on cars that were out of warranty.
Bill
Bill
Never had the FSU problem with my 03 coupe. Have yet to experience this problem with my 05 coupe. I've used nothing but Sunoco 94 Ultra gasoline in both rides.
Originally Posted by cam30era
Exactly the same thing happened on my C6 this past Friday. That's two of us.
I also had the same message at around 650 miles. Car now has 1200 miles and message has not returned. Mobil premium and sunoco ultra used.....I first thought my gauge was showing empty because the g-force was pushing all the gas back but I guess a bad part makes more sense. Does this effect anything else besides the fuel gauge?
Nice site by the way. Glad you folks are here
Dealer said the FSU was bad. Part is on order & they will have to pull the tank to repair. Said it may be ready by Wednesday.
FSU is bad I didnt think there was enough room in there for Fla State University. Just kidding
Originally Posted by smokeyburnouts
ive heard of what 99c5vert is talking about. isnt this problem on more GM models than just the corvette? my DD 99 ZR2 does this as does my buddies Blazer..he said the same thing 99c5vert said was the cause
Originally Posted by VettXPert
I tried to warn them but all they do is bash here. Like Death and Taxes you can count on GM serving you up a crappy first model year car!
Unless the issue is the engine falling out of the car, you can count on a first year problem plauging every model year of the car's run.
Same exact thing just happened to me today. No info from the dealer yet, but I assume I'm in for an FSU replacement as well. Great... just over 1000 miles, little more than a month old. I had just filled the tank with the highest octane Mobil available at most local Southern California stations (91, I believe). Nice to know that my month old car will have to have the fuel tank pulled to replace a part that was a common problem in the C5...
Steve
Same FSU Problem
My engine warning light came on at just under 700 miles followed shortly thereafter by the fuel gauge going dead and the message "Service Fuel System" coming on in the DIC. After re-starting the car, the gauge came back, but the engine warning light stayed on. After several more restarts, the engine warning light went off too. Then the whole sequence would happen again randomly as I drove around. Took it to the dealer and they first re-loaded the software which didn't work. Now they are in the process of replacing the FSU. According to the service manager, the gas should not impact the FSU, just impair performance (some pinging and loss of power) if you use the generic stuff like COSTCO. He did say that Chevron or other branded gas would be good to use every once in awhile to help keep the fuel injectors clean. He also said the replacement FSU was supposed to have gold tipped leads which might help prevent a reoccurrence, but he also said he wasn't sure whether the one installed during production had the same leads. Worse thing though was while my car was waiting to be fixed, the paint was scratched so now they also have to send it out to a body shop to have that fixed (At least they called to tell me about it instead of trying to slip it by me) In the meantime they gave me one of those huge GM full cab pick-ups as a loner. Will keep you guys posted after the FSU is replaced.
